Old 09-16-2010, 09:30 AM   #1
window doesn't retract when door opened
The window should retract slightly to clear the window frame. I have replaced the microswitch that connects to the door handle. The problem occurs on entry from outside the car and also when I am in the car and pull on the inside door handle.
Any suggestions? Thanks.
John M
JMINMD923 is offline   Reply With Quote
