Old 06-27-2015, 11:15 AM   #1
DonM
Posts: n/a
Headlight Removal Tool?
Hey guys,
The Headlight Removal Tool was not in my tool kit when I bought my car (2002 S). Does anyone know where I might find one?
I know that a 5mm socket on an extension will work... I'd just like to have an original.
thanks
Don
Old 06-27-2015, 11:48 AM   #2
Wallace River's Avatar
It must be a popular item, it was missing from the car I bought too.
The name's Ian....now a former owner.....sold my 2000 Speed Yellow Base to its new owner in Nova Scotia.
Wallace River is offline   Reply With Quote
Old 06-27-2015, 01:54 PM   #3
2002 Boxster S
Just call the parts department at your nearest Porsche dealership, they usually have them in stock.
2002 Boxster S
Ottacat is offline   Reply With Quote
Old 06-27-2015, 02:09 PM   #4
This is what the headlight tool looks like :
For the OEM item:
http://www.ecstuning.com/ES1511962/
A 5mm socket+wobble extension is an upgrade on the OEM tool:
http://www.ebay.com/itm/NEW-CRAFTSMAN-1-4-Dr-METRIC-Dual-Laser-Etched-6-PT-SOCKET-ANY-SIZE-/310494553891?pt=LH_DefaultDomain_0&var=&hash=item484aeae723
Old 06-27-2015, 03:36 PM   #5
DonM
Posts: n/a
Good suggestion... I called and they have one and are holding it for me
Old 06-28-2015, 03:52 AM   #6
The OEM tool is crap. Mine split and would not allow it to grip the shaft properly. Others have reported this too. Just use a socket and driver.
Chris
'86 944, manual steering, a/c delete, 944Max chip
'87 951, K27, LBE, Turbo S brakes, Koni Yellows, Weltmeister sway bars / strut brace, LSD, full cage, OMP race seats
'01 Boxster - Seal Grey / Black / Black, Litronics upgrade / de-ambered
crooster is offline   Reply With Quote
Old 07-01-2015, 02:33 PM   #7
Totally agree!
Old 07-01-2015, 02:51 PM   #8
Disagree. Take it from someone who actually knows.
If used correctly, the correct Porsche made tool is ideal. Sockets fall off and are a PITA.
I've used it hundreds of times. If you are using enough force to break it, you weren't using it correctly or your mechanism is bound, so you should address the real issue before you strip the lock bar and even a socket won't save you.
You'll be stuck with a headlight that you can't remove and a car that you can't drive due to burnt out bulbs that you now can't replace because you decided to use a jerry-rigged solution instead of actually fixing the problem.
But hey, what do I know
Old 07-01-2015, 03:15 PM   #9
jsceash's Avatar
I have to agree with this mine rounded out. and I have had "0" problems using a nut driver
Old 07-01-2015, 03:37 PM   #10
There Is No Substitute.
rick3000's Avatar
The PN for the OEM Headlight removal tool is: 999.571.076.02, they run about $13-15.
Edit: Just notice Gelbster posted this via a link to ECS, beat me too it!
