Old 06-09-2015, 04:42 AM   #1
poping noice from engine on take off
2000 boxster S, on take off if not giving good throttle i get this poping noise from the enging, doesn`t matter if the car is hot or cold.
Just imagine sitting on a hill, then dip the clutch and tap the throttle as you do to take off, you feel the engine like it had a stamina if you know what i mean, cant explain any better realy, once you are on the move there is not an issue at all
Please help.
ssmart is offline   Reply With Quote
Old 06-09-2015, 06:16 AM   #2
Beginner
Jamesp's Avatar
It would be great if you could post a video with audio of the popping noise.
2003 S manual
Old 06-09-2015, 06:29 AM   #3
78F350's Avatar
Has the front engine mount ever been replaced? If it's just a noise, and not a misfire or engine power type of problem, my first guess would be a worn/cracked mount.
Porsche Boxster Motor Mount Replacement - 986 / 987 (1997-08) - Pelican Parts Technical Article
Old 06-09-2015, 12:04 PM   #4
the pop comes from the right hand side engine vent....R/H drive
Old 06-10-2015, 09:03 PM   #5
That is because it is the nearest 'hole' to the outside from the front engine mount.
Just take the cover off behind the seats and blip the accelerator while watching the mount. Probably not while driving ....
