Old 05-05-2015, 09:16 PM   #1
Wheels.. will these fit??
I saw a set of wheels on Craigslist and wondered if they would fit my 2002 Base Boxster model. The rears look massive.
Wheels:
Front: 8Jx18H2-ET57 (Part#:997.362.136.00)
Rear: 10Jx18H2-ET58 (Part#:997.362.140.01)
Tires:
Bridgestone Potenza RE050A
Front: 235/40zr18
Rear: 265/40zr18
Thank you for any help, much appreciated!
Cebu is offline   Reply With Quote
Old 05-06-2015, 03:23 AM   #2
Need For Speed
KRAM36's Avatar
Yes they would using spacers. 12mm on the front and 18mm on the back.
That's a hard to find set. On eBay they go for $2,000, how much can you get them for?
http://www.ebay.com/sch/i.html?_from=R40&_trksid=p3984.m570.l1313.TR0.TRC0.H0.TRS0&_nkw=997.362.140.01&_sacat=0
2003 Boxster S
Old 05-06-2015, 05:09 AM   #3
steved0x's Avatar
Wheels:
Tires:
Front: 235/40zr18
Rear: 265/40zr18
I don't have any feedback on the wheels, but be sure to check the diameter of the tires, I recently tried to fit a set of Hankook RS-3 in the following sizes: 245/40/18 and 285/35/18.
The 285/35/18 fit in the back, but the 245/40/18 were too tall and did not fit in the front because they contacted the lower spring perch on the strut.
Here is a comparison of sizes:
It looks like your front size is the stock 987 size. I have heard that it fits but I bet it is tight. My tire was .3" taller and did not fit and it was pressed on there pretty tight.
Stock 986 Boxster front - 205/50/17 - diameter 25.1" (from Miata.net tire size calculator)
Stock 987 Cayman front - 235/40-18 - diameter 25.4" (I have heard this fits on a 986 but it is tight)
This larger front size - 245/40-18 - diameter 25.7" (too tall for 986 fronts)
If it is stock 987 sizes it would probably fit, but there is nothing like the feeling of schlepping a set of wheels and tires around, and installing them and they don't fit
Old 05-06-2015, 10:40 AM   #4
I've decided not to get them. After reading the feedback from the folks here. The wheels were listed in the Sacramento, Bay Area California craigslist. I believe the asking price is $950.
Old 05-06-2015, 10:43 AM   #5
Thanks to everyone that responded. I really appreciate the knowledge in this forum. I've decided not to get them and will look for wheels that are drop in replacements. I'm just tired of the twist styled rims. I may stay with the same 17" wheel size I have now but a different style.
Old 05-06-2015, 11:06 AM   #6
steved0x's Avatar
Here's a site which lists weights for a lot of the Porsche wheels and also includes offets, widths, part numbers, and pictures for a lot of the OEM Porsche wheels:
944racing
My favorite 17" wheel is the "Boxster S" twist, I have a dinged up set of those as my track wheels. I have a set of "996 Carrera 2" in 17" as my street wheels that I repainted using the guidance from some of the threads in the DIY section. They look pretty good from 5 feet away, as you get closer you can set a spot here or there.
There are plenty of 18s that will work on the Boxster without spacers and fiddling that can get you away from the twist look, and also some 17s.
Good luck!
Steve
Old 05-08-2015, 01:31 PM   #7
In case anybody is interested this is the craigslist link that has the wheels for sell. I have no affiliation with the seller.
http://sacramento.craigslist.org/pts/4984213873.html
Old 05-08-2015, 03:01 PM   #8
Need For Speed
KRAM36's Avatar
2007 Porsche Boxster S - 18" Staggered Wheels
Those are not even the same wheels you were asking about.
I think you meant this listing.
Porsche wheels and tires
2003 Boxster S
Old 05-08-2015, 03:02 PM   #9
LOL!! Whoops!!
