Old 05-01-2015, 10:27 PM   #1
Need For Speed
KRAM36's Avatar
Installing a fixed spoiler question.
I'm looking at installing this fixed spoiler to my car.
My question is, can I remove the motor assembly from the Porsche spoiler and still have the stability provided by the Porsche spoiler with the fixed spoiler?
The reason I would want to do this is because the places I have looked to buy this spoiler from says the shipping weight is 77lbs.
I did send an email to the company that makes this spoiler asking the weight of it, no reply yet, but if it does weigh 77lbs I need to offset that weight gain.
2003 Boxster S
Old 05-02-2015, 04:12 AM   #2
still plays with cars...
BoxsterSteve's Avatar
KRAM,
That's a fine looking spoiler. I hope the 77lb is a typo.
Six speed 2000 Boxster S
Old 05-02-2015, 04:14 AM   #3
If it's made of fiberglass or similar type product I would guess 7.7 pounds.
rfuerst911sc is offline   Reply With Quote
Old 05-02-2015, 11:10 AM   #4
EJ-Fresno's Avatar
Where did you find that spoiler? (If I may ask...)
2006 V6 Mustang
2008 ML 350
EJ-Fresno is offline   Reply With Quote
Old 05-02-2015, 12:16 PM   #5
Need For Speed
KRAM36's Avatar
Porsche Boxster Rear Wing Spoiler 986 SPEED GT by Hofele – Hofele America LLC
2003 Boxster S
Old 05-02-2015, 12:17 PM   #6
EJ-Fresno's Avatar
$800...
Not for me yet, even if it looks really good !
2006 V6 Mustang
2008 ML 350
Old 05-02-2015, 12:22 PM   #7
Need For Speed
KRAM36's Avatar
$800...
Yeah, it's not cheap. You can get it from here for a little less and if it's your first order with them you get 5% off.
https://www.horsepowerfreaks.com/hofele-speed-gt-rear-wing-porsche-boxster-96-04-p-145818.html?osCsid=ntl2kjp8qtapmkt92t82ddt8a1
2003 Boxster S
Old 05-02-2015, 03:50 PM   #8
I'd suggest checking with the manufacturer to see if they have done any testing or have any predictions.
Old 05-02-2015, 04:45 PM   #9
Need For Speed
KRAM36's Avatar
Good idea. I'll do that if they respond back on the actual weight of the spoiler.
Hard to believe this spoiler weighs 77lbs. If it does I may just forget about it.
2003 Boxster S
Old 05-02-2015, 05:42 PM   #10
Rennzenn
j.fro's Avatar
No way that weighs more than 10 pounds. Pulling the factory spoiler motor will offset everything. With some creativity you'll have a net loss. You'll want to pull the spoiler bulb from the dash... As soon as you hit 75 and the spoiler doesn't go, the light will come on as a fault.
Rennzenn
Jfro@rennzenn.com
Old 05-02-2015, 06:18 PM   #11
Need For Speed
KRAM36's Avatar
Check this out. Add it to cart then look at the weight.
2003 Boxster S
Old 05-02-2015, 10:21 PM   #12
From their site:
The spoiler is being placed in front of the serial spoiler, the serial spoiler stays in place and is still working.
The two spoilers form a bigger surface which results in a better down force.
The spoiler is glued onto the car, the special glue is included.
Looks like they expect you to leave the original in functioning condition...
ianacole is offline   Reply With Quote
Old 05-03-2015, 03:39 AM   #13
Need For Speed
KRAM36's Avatar
Question is, am I going to need that extra down force?
To me the spoiler I'm looking to buy would actually give more down force then the Porsche stock spoiler, as the spoiler I'm looking at actually has a bit of wing built into it.
2003 Boxster S
Old 05-03-2015, 04:56 AM   #14
Rennzenn
j.fro's Avatar
heres a pretty good spoiler/wing article:Wings/Spoilers: You're probably doing it wrong.
I like the look of the spoiler you are considering. Unless you are on the track going 9/10 or higher, you'll never notice any difference.
Rennzenn
Jfro@rennzenn.com
Old 05-03-2015, 06:18 AM   #15
Need For Speed
KRAM36's Avatar
That's what I'm thinking. I don't track my car, no tracks near me. I do have some favorite twisty roads outside of town I love to hit. Most of the corners are probably between 35 to 60 mph, but there is one that's a long up hill sweeping corner that I can do 100+ mph through it right now on snow tires.
While I have your attention. I'm looking at fiberglass front and rear hoods. They would be lighter then the stock hoods, right?
2003 Boxster S
Old 05-03-2015, 06:24 AM   #16
Rennzenn
j.fro's Avatar
Be careful on the snows 😉
The CF hod on my car saved 30+ pounds. The FG trunk lid saved a few, but I don't remember the exact numbers.
Rennzenn
Jfro@rennzenn.com
Old 05-03-2015, 06:40 AM   #17
Need For Speed
KRAM36's Avatar
Carbon Fiber starts getting pricy compared to Fiberglass. Is there no weight saving in the Fiberglass?
2003 Boxster S
Old 05-03-2015, 09:08 AM   #18
jsceash's Avatar
The easy answer is yes about 50% of the difference in Carbon Fiber to the original piece for a fiber glass part. If you look at 30 pound saving in carbon possible 15 pound in Fiberglass
The thing to think about is the quality of the part? Carbon fiber manufacturer for the most part fabricate a part close to ready for installation because the vast majority are only cleaned, wet sanded, and clear coated because they intend the fiber look for it's aesthetic. Fiberglass manufactures up front will tell you the part may need adjusted for fit and finish because they know it need adjusted sanded primer and finished with paint and sealer.
Consider you cost as the price of the part plus steps to finish it. With this in mind you may find Carbon fiber cheaper.
Old 05-03-2015, 10:35 AM   #19
Lighter front and rear hoods are beneficial in two ways - not only can you save total weight but it also saves weight up high which lowers the center of gravity for improved handling.
Old 05-03-2015, 08:59 PM   #20
Need For Speed
KRAM36's Avatar
Found a Carbon Fiber rear deck lid for $400 shipped. Anyone want to share a place to get a Carbon Fiber front hood at a decent price or rear deck lid at a better price? Prefer one that doesn't need pins in the hood either.
The hoods will be painted, so I'm just looking for Carbon Fiber, nothing fancy.
Ran across this one for $840 shipped. Anyone have one cheaper?
http://www.streetbeatcustoms.com/Custom/Hoods/98_04-PROSCHE-BOXSTER-911-996-OEM-CARBON-FIBER-HOOD/17350/
Oh yeah! This baby is going on the hood! Came up on my search for Boxster Carbon Fiber hoods.
2003 Boxster S
