Old 03-31-2015, 07:35 PM   #1
Hose Identification
noticed today that this hose was broken, I was able to "MacGyver" it, but would like to replace it properly with the OEM part. anyone know what it is called?
kiyakubuke is offline   Reply With Quote
Old 04-01-2015, 02:51 AM   #2
Need For Speed
KRAM36's Avatar
#27 in this diagram.
M96.21/22 Air Injection 00-02 M96.23/24 03-
They show no part # for it or even sell it. Hopefully you got it fixed.
I needed one and found it on eBay.
2003 Boxster S
Old 04-01-2015, 06:09 AM   #3
Artist, 986S tinkerer
NewArt's Avatar
Standard vacuum hose, if it's that to which you are referring. That's why there is no
part #.
MacGyvering is fine but it means the hose is probably getting brittle and should be replaced at some point to avoid a vacuum leak.
Old 04-01-2015, 12:41 PM   #4
Some of the vacuum hoses are very difficult to access and trace. You could easily do more damage /crate other problems removing things -be careful. I have used 3mm silicone vacuum hose as a repair sleeve over broken vacuum hoses as a temporary fix. Pick a silly bright color so you can see where the repair is and notice if it fails easily. YEMV.
Old 04-01-2015, 04:30 PM   #5
Wrong side of the car. That is the vacuum hose for the fuel pressure regulator. Any appropriately sized vacuum hose will do as a replacement.
specboxCO is offline   Reply With Quote
Old 04-01-2015, 07:19 PM   #6
Need For Speed
KRAM36's Avatar
I stand corrected. specboxCO is right.
2003 Boxster S
