03-17-2015, 11:08 AM
Hard brake lines
Hey guys, I have a question about the bubble flare on the hard brake lines. I read on some other forums that its a compression seal and once broken, it can not be reused because it won't seal. You have to cut the flare off and reflare the tube. Is this true?
Also, does anyone know the tread size on the flare nuts? There are two different sizes. I would like to get some new nuts.
03-17-2015, 12:29 PM
Most brake hard lines are a double flare style, which requires specialized tooling to create. Because of the pressure they operate under, they cannot be made with a common single flare tool. Flare fittings can be opened repeatedly and will completely reseal as long as neither side of the flare fitting is damaged in anyway.
Fittings on Porsches are metric and tend to use 18MM, 17MM, 14MM and 11MM, depending upon year, model, and location of the fittings. There may also be one of two other odd sizes, again depending upon the car. You should never attempt using an open end wrench on a brake line fitting, you need proper flare fitting wrenches to have any chance of preventing rounding off the flats on the fittings:
03-17-2015, 03:48 PM
Thanks for the reply. I'm aware of the flare types and flare nut wrenches. The nuts were not rounded, I just to to replace them because I have a chance to. Part of the line on my car has quite a bit of rust on it, so I would like to replace it. I plan on either buying or renting a flare tool and a tube bender.
I actually found a video that explains the tube flares. It's confirmed that you can not reuse european style bubble flares (at 2:08). https://www.youtube.com/watch?v=_C12aUE6Qlk
03-17-2015, 05:25 PM
You do not have "bubble style flares" on the car which are used on soft steel lines, the ones on the car are double flares in hard steel lines which remain fixed, and are completely reusable. We open up these double flares regularly, and have never had a problem with them resealing.
03-17-2015, 05:29 PM
Oh cool, good to know! Thanks!
03-19-2015, 09:21 AM
Hey, I'm just at the shop looking at the brake lines and it looks a lot like the bubble design. Could you please have a look at the pics( I'm sorry about the size, I'm on my phone). What do you think?
The reason I decided to double check because I though that double flare is only used in american cars.
03-19-2015, 10:38 AM
That is a DIN/ISO double flare (sometimes call a "mushroom" flare), which is reusable:
If the end of the tubing looks like a button and the back side angle of the flare is 90 degrees it is the DIN flare. If you look at the true "bubble" photo above, the back side is rounded. You must use a nut with a "lead" for the DIN flare (nut has unthreaded tip).
M1-3 10 x 1.00MM common European/DIN nut with DIN flare
To make this style flare, you need a very special style of tool.
03-20-2015, 08:29 AM
Hey,
I don't want to get into a technical argument because I'm no an expert myself, but DIN or ISO is a "bubble flare", I believe double is the term for SAE flare. I just spoke to my local Porsche mechanic about it, and he said they are technically not reusable because they have a crush zone for sealing, but 90% of the time you won't have any issues with it. He said when he does the work for customers he would have to re-flare the line, but he wouldn't worry about it on a personal car.
03-20-2015, 09:51 AM
Hey,
Calling it a bubble flare is a common misnomer, I have even seen it listed in publications that way; and it is completely reusable.
03-20-2015, 10:15 AM
I've just searched some brake line manufacturer's websites, and you may have a point as some are listing their versions of it as a "DIN/ISO "bubble" style". All of the old bubble type fittings I am familiar with (found on Alfa, Fiat, etc.) the completely rounded bubble tube end either crushed or deformed the first time it was tightened, making it impossible to reuse, and was typically found only on soft alloy tubing. The DIN/ISO type has a 90 degree back angle rather than a curved surface, uses a special nut, does not deform unless seriously over tightened, is found only on hard steel (read difficult to shape or bend) tubing, and is used on many different manufacturers, including several US cars like the Corvettes.
As I mentioned previously, we put them back together all the time and have never had one leak.
03-20-2015, 10:44 AM
JFP in PA is right.
This brake lines are reusable as long as they are not damaged by an accident, by rust, or something else. If the line has corrosion, please allways replace it. Take care of the tip. This has to be 100% intact. Else please replace. If you not 100% shure, replace it. Brakes systems are essential for your and others lives.  Don't make savings at the wrong spot.
Regards Markus
