Old 03-12-2015, 02:45 PM   #1
Need For Speed
KRAM36's Avatar
Durametric Actual Values Shows Misfire Cylinder 3
I was just running down the Durametric Actual Values list checking to see what info it would show me. I got to the Cylinder Misfire section and it is showing Cylinder 3 as having misfires.
I did the norm from what I read on a search here. Changed the coil, still shows misfires, changed the spark plug, still shows misfires.
Apparently it's not bad enough to throw a CEL on it, but I want to fix this. No other Cylinders showed a misfire. Could it be the fuel injector?
2003 Boxster S
Old 03-12-2015, 05:39 PM   #2
Need For Speed
KRAM36's Avatar
Ok, took the car for a long drive and during the drive there were 0 misfires, pulled into the driveway and at idle got misfires again.
2003 Boxster S
Old 03-12-2015, 06:43 PM   #3
a leaking injector perhaps..?
Old 03-12-2015, 06:54 PM   #4
Jager's Avatar
I would try a good fuel injection cleaner. If that doesn't work run a compression check on that cylinder.
Jäger
300K Mile Club
Old 03-12-2015, 07:35 PM   #5
Need For Speed
KRAM36's Avatar
I put a bottle of CRC complete fuel system cleaner in it today.
CRC/12 oz. Guaranteed to Pass complete fuel system cleaner 05063 at AutoZone.com - 4 reviews
2003 Boxster S
Old 03-13-2015, 05:48 AM   #6
Need For Speed
KRAM36's Avatar
Took a drive, probably 20 to 25 min long. Had my daughter with me to watch for misfires on cylinder 3 and there were 0 misfires during the drive.
Once back in the driveway at idle Durametric showed misfires happening again on cylinder 3.
2003 Boxster S
Old 03-13-2015, 06:28 AM   #7
The Radium King's Avatar
it may be that your high idle adaptation and cyl 3 misfire are related.
1. confirm your vacuum leak from the other thread. a vacuum leak has more overall effect at idle, and both your issues are idle-related.
2. disconnect maf and see if problem persists. a dirty maf can cause gremlins like this (and you are running an oiled filter ...).
3. clean injectors. improper fueling due to improperly performing injector may be the culprit.
Old 03-13-2015, 07:05 AM   #8
Need For Speed
KRAM36's Avatar
I did the vacuum leak test, see other thread. I blew out the filter with a leaf blower to remove excess oil on the filter. I also cleaned the maf sensor yesterday and put that complete fuel system cleaner in the car along with Quick Trip Premium fuel.
The car runs like a monster, pulls ever gear really good.
2003 Boxster S
