Old 03-02-2015, 09:55 AM   #1
Thread size on the water temperature sensor?
Does anyone know the thread size on the water temperature sensor? This is for a 2000 Boxster S
martsink is offline   Reply With Quote
Old 03-02-2015, 06:01 PM   #2
1999 base
Meir's Avatar
the thread size is 14mm.
Old 03-02-2015, 06:12 PM   #3
Thank you! That's m14x1.5 I'm assuming?
Old 03-03-2015, 11:30 AM   #4
1999 base
Meir's Avatar
i whould say just yes, but i needed to type more then 10 characters .
Old 03-03-2015, 11:32 AM   #5
Haha thanks!
Old 03-03-2015, 11:34 AM   #6
1999 base
Meir's Avatar
wait a second.
i just saw your other thread.
are you planing to install the OEM temp sensor on your V8 engine?
Old 03-03-2015, 11:38 AM   #7
wait a second.
Yeah, I need it for the gauges to work. Porsche sensor will go in the left head and GM sensor in the right.
Old 03-03-2015, 12:15 PM   #8
1999 base
Meir's Avatar
i'm not sure if the temperature sensor connects directly to the cluster, or goes Through the ECU.
i suggest you look at electric diagrams, as i assume you are not going to use the OEM ECU, but the V8 one.
what year is your boxster (and cluster)?
Old 03-03-2015, 12:20 PM   #9
Its a 2000 Booster S. I will actually be using the Porsche ecu to run some stuff like the gauges, fuel pump, etc . I'll have to cut down the harness quite a bit of course.
Old 03-03-2015, 12:37 PM   #10
1999 base
Meir's Avatar
in that case your good to go.
good luck, and update us with your project.
sounds very interesting, and i'm sure people hear would love to see some pics of the process.
