Old 01-07-2015, 01:34 AM   #1
mavis.d's Avatar
Coolant light
The other night driving home the coolant light came on permanently. I have checked the level in the expansion tank and all is ok. I have disconnected the battery for 10 mins to see if it reset but no. The other thing to note is that often when reversing I can hear air in water at the front, a sort of sloshing. Any suggestions?
Thanks in advance
David
mavis.d is offline   Reply With Quote
Old 01-07-2015, 02:33 AM   #2
Thanks in advance
David
Disconnecting the battery when a MIL is triggered is always a bad move; when you do that, you have lost all of the data accumulated in the DME, which would have been helpful in diagnosing your issue.
I would not be starting or running the car until a shop can look at it. Overheating one of these engines can be disastrous.
Old 01-07-2015, 04:47 AM   #3
mavis.d's Avatar
Ok but temp remains solid 80c which it always has done
Old 01-07-2015, 07:20 AM   #4
Four functions of the coolant warning light:
1. Engine coolant level too low -- light flashes slowly (0.5 Hz)
2. Engine compartment temperature too high -- light flashes slowly (0.5 Hz) (engine compartment blower might be faulty)
3. Engine coolant temperature too high -- light is lit; pointer on the right
4. Temperature sensor at water outlet faulty -- light flashes rapidly (1 Hz) ; pointer on the right
Old 01-07-2015, 05:29 PM   #5
Stuck thermostat maybe?
Or perhaps a plugged rad? When was the last time you took off the front bumper and cleaned out all the debris from between the rads and condensers?
I'd be concerned about the sloshing noise. Carpet wet in the frunk?
'99 black 986
Old 01-07-2015, 09:27 PM   #6
Steve Tinker's Avatar
I agree - I'll bet the OP hasn't cleaned out his drains lately..........
2001 MV Agusta F4.
Old 01-08-2015, 12:17 PM   #7
woodsman's Avatar
Air in the heater core? Pressure test.
Please note that I am a taxi driver- NOT a mechanic.
Old 01-09-2015, 01:05 AM   #8
mavis.d's Avatar
Light is not flashing but on constantly
Don't think it's debris as it's quite clean in the rads. All carpets dry
Worth a look, as temp control of the heater is a little erratic
Cheers
David
Old 01-09-2015, 07:07 AM   #9
I cant answer the question about the cooling temp light, but the water sloshing in the front might be the cowling drains. The space were the battery sits has a couple of drains and does collect water.
Old 01-09-2015, 07:27 AM   #10
mavis.d's Avatar
Once again no all dry, it's more of the sound of air in pipes
Old 01-09-2015, 09:37 AM   #11
Pull a vacuum on the system using the vacuum filling tool; if there is any air in it, it will come out and the level in the tank will drop. If it does go down, you need to use the vacuum tool to add more coolant 50/50 mix.
