Old 12-16-2014, 11:14 AM   #1
jaykay's Avatar
DME relay removal for engine cranking
Is there any negative to removing the DME relay for engine cranking without staring?
....it's for building up oil pressure prior to start..after engine work
986 00S
Old 12-16-2014, 11:28 AM   #2
Just take out the fuel pump fuse. Very easy.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
Old 12-16-2014, 09:36 PM   #3
jaykay's Avatar
Yes that would be easier but I would think that there is a good chance of it catching and dying. Ignition is still there along with fuel. I was hoping that the relay removal would take away ignition with no detrimental effects.
The goal being to strictly limit the engine to cranking rpms
986 00S
Old 12-17-2014, 05:47 AM   #4
kk2002s's Avatar
I have been thinking about this same issue
Now that car sits 2-3 weeks at a time and it's a very cold start, It ain't Pretty
I have resorted to cranking and turning off ignition a couple times before it catches
This makes for a more quiet start up but it somehow prevents the Secondary Air pump from coming on and it's a bit rougher as there is gas loaded up
Seal Grey
Old 12-17-2014, 10:15 AM   #5
jaykay's Avatar
Yeah, I jog it with the key over something like 5 mins....not good for the starter or positive oil pressure
986 00S
Old 12-17-2014, 10:39 AM   #6
We have customers that store their cars in near zero conditions for months at a time without ever starting them. And when spring comes, they light right off with no ill effects. As long as the oil remains fresh, which it won't if you keep starting the car all winter, and you used an oil with good film strength, letting it sit for several months will not cause any problems.
Unless you have had the engine apart, or replaced part of the oiling system, there is no need to wind the car into oil pressure, it will nearly instantly get there all by itself when normally starting it.
Old 12-19-2014, 09:55 PM   #7
jaykay's Avatar
...so assume there is just cause DME relay out and crank is okay???
986 00S
Old 12-20-2014, 12:35 PM   #8
Steve Tinker's Avatar
Just pull the fuel pump fuse - the engine will not start up as the fuel pressure drops over a couple of hours. That's why you hear the fuel pump run when the ignition is first switched on from an overnight stop. Try it - it will take a minute to prove.......
If you are determined to go down this road, you could easily wire the fuel pump to an isolation switch on the console for cold starts.
2001 MV Agusta F4.
