Just pull the fuel pump fuse - the engine will not start up as the fuel pressure drops over a couple of hours. That's why you hear the fuel pump run when the ignition is first switched on from an overnight stop. Try it - it will take a minute to prove.......
If you are determined to go down this road, you could easily wire the fuel pump to an isolation switch on the console for cold starts.
2001 MV Agusta F4.
