Old 11-15-2014, 01:21 PM   #1
embryoguy@mac.com's Avatar
motor mount issue
how do i know if i have a motor mount issue? when i downshift sometimes i feel a bump.
embryoguy@mac.com is offline   Reply With Quote
Old 11-15-2014, 02:20 PM   #2
BYprodriver's Avatar
If it has never been replaced or it doesn't have a 987 part# it needs to be replaced for sure. The symptom seems to indicate a worn motor mount.
Old 11-15-2014, 04:29 PM   #3
I also noticed a vibration / resonance around 3k that went away after changing the mount. It's not that expensive a part and a fairly easy task to swap it out, so I am glad I did mine. The old one was definitely cracked and on its way to complete failure.
Chris
'86 944, manual steering, a/c delete, 944Max chip
'87 951, K27, LBE, Turbo S brakes, Koni Yellows, Weltmeister sway bars / strut brace, LSD, full cage, OMP race seats
'01 Boxster - Seal Grey / Black / Black, Litronics upgrade / de-ambered
crooster is offline   Reply With Quote
Old 11-15-2014, 06:22 PM   #4
Reebuck1
3.4 motor swap in 1998 boxster
Finally got the motor in the car and started it up today....major mile stone.
I had my DME re-flashed with a ROW flash. Am running CAT by pass pipes with no muffler as of yet.
Put the boxster 2.5 pre-CAT oxygen sensors on the by-pass pipes.
No seats in car yet.
Motor started right up...at idle ...NO FAULTS !!!
blipped the throttle a few times and got the following FAULT CODES:
P1319
P1318
P1317
P0300
P0306
P0305
P0304
P0150
I am only guessing......... I have a bad Oxygen sensor in bank 2 (4,5,6)
DME is 5.2.2 from the 2.5 Boxster
Intake and throttle body is from the 996 Carrera
Air filter box is from a 987 but converted to fit in the 986
3 1/2 inch silicon piping runs from air filter to throttle body
MAF is stock from the 996 with the 3 inch 987 tub that holds the 996 MAF
MAF is located approximately 6 inches from the throttle body opening.
oxygen sensors are the stock 2.5 oxygen sensors
Reebuck1 is offline   Reply With Quote
Old 11-15-2014, 10:07 PM   #5
ok thanks crooster/ diver , ill go ahead and have it done. thank you ! ok ill ask for 987 part number
