11-09-2014, 01:13 PM
Beginner
Bank 1 and Bank 2
My Boxster books are packed for a move and my electronic manuals died with a computer so I'm going on memory. If you can, please confirm Bank 1 is on the right side, bank 2 is on the left side of the car with the engine installed. I'm still fighting a P1331 code and want verify I'm working on the correct bank.
2003 S manual
11-09-2014, 01:45 PM
Bank #1 is the passenger's side.
11-09-2014, 03:41 PM
Beginner
Ok, that means the passenger side on a left hand drive vehicle? So I'm thinking that means bank one is on the right side of the vehicle?
2003 S manual
Reason: clarity
11-09-2014, 01:46 PM
Edit: Tried to directly link image but couldn't figure it out... The pic is on the page in the previous post.
11-09-2014, 03:57 PM
Try this:
11-10-2014, 04:38 AM
Hey, this is not a boxster engine, the oil fill tube is pointing towards the front where the drive belts/pulleys are. Or maybe the pulleys are on the wrong end!
11-10-2014, 06:07 AM
Engine Surgeon
Bank 1 of the engine is always viewed from the flywheel end looking forward and is on the right. Bank 2 is always on the left side.
No matter which direction the engine is installed in the vehicle, always view from the flywheel end looking forward to keep it simple.
US Patent 8,992,089 &
US Patent 9,416,697
11-10-2014, 06:15 AM
I ran into this issue years ago when I rebuilt my engine lol!
Remember, the boxster motors are are 180 degrees rotated in relevance to the 911 motors. So bank 2 would be on the left hand side for us and bank 1 would be passenger. (reversed for the Brit's)
11-10-2014, 12:03 PM
Beginner
Thanks everybody. I thought I had the banks correct but wanted to confirm. So the plot sickens. I replaced the camshaft sensor and still got the error code, swapped sensors between banks and still have the same Durametric reading "spec angle for camshaft 2 = 0.00", along with the error code "P1331 Porsche fault code 903 - Inlet camshaft bank 2 Driver"
I buzzed out the 3 wires from the connector at the sensor to the connector in the trunk and all 3 have continuity (sewing pins work great to probe the connectors btw).
So what is next? Is this a computer problem? Everything looks new, no water or mechanical damage anywhere in the system.
Does anyone know what the signals on those 3 lines are supposed to be or how to buzz them out? Is one of them a 12 volt signal I can check? Just what is a bank 2 driver anyway? I thought I was the driver but apparently not, at least not lately, looks like bank 2 is driving, or not... As always, any help, experience, thoughts, or even wild ideas are appreciated.
2003 S manual
