Old 10-16-2014, 08:53 PM   #1
Beater Boxster ODB2 readout.. Ugh!!
I found a Durametric cable on Craigslist and snagged it up. After fumbling around getting their software to work with my Macbook Air I was able to perform a diagnostics.
I have a bunch of failures fitting for my Beater Boxster. I now see why my alarm always "double beeps" when turning it off. (check out the readout below)
My first plan of attack are the errors P1137 and P0430. I believe the P0430 is the reason my CEL comes once in awhile.
Durametric Readout:
"Porsche fault code 45 - Cat conversion bank 2 exceeds limit value"
Bentley Service Manual:
“TWC conversion cylinders 4-6” [Short to ground / below lower limit / lean mixture threshold]
I’ve searched around the internet trying to decipher what this means and there seems to be a variety of fixes such as a bad 02 sensor, air filter, MAF or catalytic converter. I’d like approach this with your experience in troubleshooting. I have the durametric cable/software, multimeter, oscilloscope and tools, just need some guidance.
Thank you in advance!
Here’s Beater Boxster Printout:
Work Log
Short Test
Bosch Digital Motor Electronics Motronic 7.2
Current Fault Codes
P1137:
Porsche fault code 446 - Clutch switch Signal implausible
P0430:
ABS/PSM 5.7
No Faults Found
Instrument Cluster K21
No Faults Found
Airbag B05
Automatic Air Conditioning H01
No Faults Found
Alarm I32
Current Fault Codes
47:
Control locking synchronization
Status: present
Occurance Counter: 32
60:
Central locking limit position Lock not reached
Status: not present
This fault is displayed for informational purposes, it is not an indication of a
problem and no repair is needed.
61:
Central locking limit position Unlock not reached
Status: present
Occurance Counter: 57
Litronic headlights HBA
Park Assist
Seat Memory
Cebu is offline   Reply With Quote
Old 10-17-2014, 08:04 AM   #2
Artist, 986S tinkerer
NewArt's Avatar
Clear the codes and see what comes back after a day or so.
When the car is warmed up, using the Durametric, go to actual values and click on O2 sensor voltage before and after cat 2. I f you get a more ore less flat line and a wavy line, the cat is good. If both lines are wavy, the cat may be bad. I picked up a used cat from European Parts Depot on eBay for $120. It came with two O2 sensors. The problem is now gone and as a bonus, it also cleared up the SAI code I was getting! I don't know why this is but I'm not complaining!
Old 10-17-2014, 10:51 PM   #3
I'm going to try this tomorrow morning. I did a reset prior and the CEL went away. It came back on I'm guessing after 150 miles of driving. Same error. Thank you for your feedback it's much appreciated!
Old 10-24-2014, 12:45 PM   #4
I have a set of spare cats with 02 sensors off my '99 2.5l
If you need them PM me.
Justin
justin-in-athens is offline   Reply With Quote
Old 10-24-2014, 07:42 PM   #5
Good evening Justin, I PM'd you..
Justin
