Beater Boxster ODB2 readout.. Ugh!!
I found a Durametric cable on Craigslist and snagged it up. After fumbling around getting their software to work with my Macbook Air I was able to perform a diagnostics.
I have a bunch of failures fitting for my Beater Boxster. I now see why my alarm always "double beeps" when turning it off. (check out the readout below)
My first plan of attack are the errors P1137 and P0430. I believe the P0430 is the reason my CEL comes once in awhile.
Durametric Readout:
"Porsche fault code 45 - Cat conversion bank 2 exceeds limit value"
Bentley Service Manual:
“TWC conversion cylinders 4-6” [Short to ground / below lower limit / lean mixture threshold]
I’ve searched around the internet trying to decipher what this means and there seems to be a variety of fixes such as a bad 02 sensor, air filter, MAF or catalytic converter. I’d like approach this with your experience in troubleshooting. I have the durametric cable/software, multimeter, oscilloscope and tools, just need some guidance.
Thank you in advance!
Here’s Beater Boxster Printout:
Work Log
Short Test
Bosch Digital Motor Electronics Motronic 7.2
Current Fault Codes
P1137:
Porsche fault code 446 - Clutch switch Signal implausible
P0430:
ABS/PSM 5.7
No Faults Found
Instrument Cluster K21
No Faults Found
Airbag B05
Automatic Air Conditioning H01
No Faults Found
Alarm I32
Current Fault Codes
47:
Control locking synchronization
Status: present
Occurance Counter: 32
60:
Central locking limit position Lock not reached
Status: not present
This fault is displayed for informational purposes, it is not an indication of a
problem and no repair is needed.
61:
Central locking limit position Unlock not reached
Status: present
Occurance Counter: 57
Litronic headlights HBA
Park Assist
Seat Memory
