10-15-2014, 10:57 AM
deep sump group buy - 20% off mantis
10-15-2014, 11:20 AM
Nice got one already..
986 00S
10-15-2014, 12:57 PM
Originally Posted by The Radium King
Thanks, I think I made 10, so the 20% discount should be on!
10-15-2014, 01:35 PM
grd clearance
Might be interested but given the state of roads I travel ground clearance is an issue.
Anyone know what effect the 1.2 or 2 liter versions have on ground clearance? Didn't see this info on their web site. Thanks.
10-15-2014, 03:00 PM
I have the 1.2 L / lowered and there are no ground clearance issues. It's well tucked in.
The group buy organizer indicates the 2 L remains above other lower components. I went with the 1.2 L when it first came out may even be one of the first installations.
The following features sold me: one piece design; largest oil volume available (at that time); and most of all the windage tray.
Nobody had the windage tray. It gives you a restricted volume of oil at the pick ups and the swirl pots return the oil below the tray
986 00S
10-15-2014, 03:57 PM
I prefer the FVD billet pan.
10-15-2014, 04:54 PM
Compare / contrast / defend?
10-16-2014, 08:36 AM
Because it is a 1 piece cnc machined pan, it has grooves cut into the bottom to aid heat dissipation, & it comes with a stainless steel internal baffle that seals better than the X-51. Adds 3/4 qt oil capacity.
FVD Brombacher Online Shop - FVD20798801 - Oil pan, FVD Motorsport - ENGINE → Motorsports
