Old 10-06-2014, 06:16 PM   #1
Known issues list
Problem#1: Leaky rear washer
Resolution: Replace the leaky rear washer
Workaround: None
Problem#2: Rear Camera out of focus/ blurry
Resolution: No resolution available yet
Workaround: None
Problem#3: Passenger door and hood clearance issue, paint damage
Resolution: Take to dealer; some are able to fix it
Workaround: None
Problem#4: False alarms
Workaround: Press lock button twice to disable alarm
Problem#5: No spare tire on delivery
Resolution: Spares are on manufacturers back-order, dealer to provide
Workaround: Emergency repair kit with sealant, compressor etc. available
Problem #6 : Side mirror adjusts up on reversing instead of down
Resolution: Put vehicle in reverse, adjust mirror to desired position. Should be recalled on next use.
Workaround: see above
Problem #7 : B Pillar trim piece cracking
Resolution: Dealer replacement under warranty
Workaround: ignore?
Problem #8 : Windshield wipers auto-sweeping on vehicle start
Resolution: See dealer for wiper issue
Workaround: none
Problem #9 : Trailer control module draining battery
Resolution: See dealer for TSB: reflash indicated.
Workaround: Unknown.
Problem#10 : One liner problem
Resolution: One liner resolution if exists today via dealer or Porsche promise
Workaround: One liner; if any workaround that fixes the problem
This is originally posted in macanforum.com and edited by me. Hope this helps anyone that needs it.
guesswecan777 is offline   Reply With Quote
Old 10-06-2014, 07:17 PM   #2
My alarm keeps going off for no apparent reason. Dealer said interior alarm sensors are too sensitive and they should have parts in about a month and will replace. Is anyone else having this issue?
gwee is offline   Reply With Quote
Old 10-07-2014, 10:08 AM   #3
It would help if there was a little background on the model year, model number, dealer delivering, etc.
Old 10-10-2014, 01:41 AM   #4
Problem #7 : Spurious wipes
Resolution: None
Workaround: None
Problem #8 : Gurgling sound from front
Resolution: None
Workaround: None
carlon cai is offline   Reply With Quote
Old 10-10-2014, 07:17 AM   #5
JayG's Avatar
Junk thread for this forum
These are obviously not 986 problems
Even stated it is from a Macan forum
Workaround: None
Workaround: None
Workaround: None
Workaround: ignore?
Workaround: none
Old 10-10-2014, 07:22 AM   #6
Standby for more links about junk porsche piwis cables. Why havent these "two" idiots been banned yet?
Old 10-11-2014, 07:53 PM   #7
Gary D
So, I was driving down the road and all four wheels fell off my dogbox, I don't have enough pancakes, and I think the answer is an orange, because a vest doesn't have sleeves. Is there a knockoff China cable that will diagnose this? Hmmm, GuessweCAN'T!
Gary_d is offline   Reply With Quote
Old 10-12-2014, 12:36 PM   #8
Yes porsche piwis cable can diagnose tire falling off! Use with old version of durametric! So simple and cheap work so good!
(Leaves to create another account to agree with post)
Old 10-12-2014, 12:49 PM   #9
78F350's Avatar
There are CATS on my soft top.
***waiting for thread to be locked, and bans for all contributors.***
Old 10-12-2014, 06:14 PM   #10
Damn Yankee
TeamOxford's Avatar
Top Speed makes "cat delete" pipes.
You may want to try that.
Just sayin'...........
TO
Tags
alarm , battery , issue , leak
