Old 10-10-2014, 06:17 AM   #5
JayG
On the slippery slope
JayG's Avatar
Junk thread for this forum
These are obviously not 986 problems
Even stated it is from a Macan forum
Originally Posted by guesswecan777 View Post
Problem#1: Leaky rear washer
Resolution: Replace the leaky rear washer
Workaround: None
Problem#2: Rear Camera out of focus/ blurry
Resolution: No resolution available yet
Workaround: None
Problem#3: Passenger door and hood clearance issue, paint damage
Resolution: Take to dealer; some are able to fix it
Workaround: None
Problem#4: False alarms
Workaround: Press lock button twice to disable alarm
Problem#5: No spare tire on delivery
Resolution: Spares are on manufacturers back-order, dealer to provide
Workaround: Emergency repair kit with sealant, compressor etc. available
Problem #6 : Side mirror adjusts up on reversing instead of down
Resolution: Put vehicle in reverse, adjust mirror to desired position. Should be recalled on next use.
Workaround: see above
Problem #7 : B Pillar trim piece cracking
Resolution: Dealer replacement under warranty
Workaround: ignore?
Problem #8 : Windshield wipers auto-sweeping on vehicle start
Resolution: See dealer for wiper issue
Workaround: none
Problem #9 : Trailer control module draining battery
Resolution: See dealer for TSB: reflash indicated.
Workaround: Unknown.
Problem#10 : One liner problem
Resolution: One liner resolution if exists today via dealer or Porsche promise
Workaround: One liner; if any workaround that fixes the problem
This is originally posted in macanforum.com and edited by me. Hope this helps anyone that needs it.
2004 996 Targa Tip
Instructor - San Diego region
