Old 10-08-2014, 10:37 AM   #1
Strange behaviour after battery change
Hello all, it has been a while but im back. Im back with a problem however. I shamefully havent driven my boxster in 6 weeks. Went to start it the other day and it was dead. Called the AA out as I have the cover and they gave me a brand new battery. The old one was the day 1 battery 14 years old, so it had a good innings. Well this is where things started to get odd. After the battery change my passenger window wouldnt go down. Neither by the switch or when you opened the door. I thought nothing of it and I can cope without it "money is tight". Next day driving around went to get out the car and the drivers side window didn't drop. So to close the door I had to pop the roof. When I unlatched it, it didnt do its initial raise that it used to do neither did the windows drop. SoI have checked all the fuses, done a battery reset. To recap, The windows dont drop and they dont operate by the switch. Any ideas? Thank you
hotel-stu is offline   Reply With Quote
Old 10-10-2014, 04:32 AM   #2
An update
I have had an auto electrician look at the car today and he thinks the relays in the window motors have both failed, strange but there we go. I have ordered 2 new ones and will update again once fitted
Old 10-13-2014, 03:52 AM   #3
It's very unlikey two seperate components failed. The window home position does have to be reset when the battery is disconnected, but they should still function, just not the "one touch" feature. You could also check the fuse if nothing works.
