Old 08-23-2014, 09:23 AM   #1
What is this stuff?
I've done a search yes, and can't come up with anything. I'm referring to that rubberized yellow coating that seems to be sprayed over various parts of the underside. It's safe to assume it's some sort of undercoating, but it seems to be applied to some odd areas.
I was doing a little feather dusting under there and this stuff started flaking off. Well that didn't look right, so I strategically scrubbed some more off and a lot of pieces came to life. I don't drive the car in rain or snow so I don't believe there will be any drawback, but I'm wondering now if this stuff had any other intended functionality.
Jim Rockford is offline   Reply With Quote
Old 08-23-2014, 02:25 PM   #2
I believe that its used for anti-corrosion and sound deadening.
Old 08-23-2014, 04:05 PM   #3
Steve Tinker's Avatar
Its called Cosmoline - it's a spray on grease that's used as a preservative and protectant. Lots of automobile manufacturers use it on /under their cars, used as a barrier against road salt & humidity .....
2001 MV Agusta F4.
Old 08-23-2014, 05:22 PM   #4
Beryllium Annihydrious Sulphuridic Xenophobic Troxin.
RickG is offline   Reply With Quote
