Old 08-20-2014, 09:10 AM   #1
Question OBD fuse?
Sorry to be needy on my first post. I'm trying to use the OBD port on my 2002 Boxster but the port is dead. I'm told to check the fuse and all should be well. I've searched here and google, but can't find the answer.
Which fuse is used by the OBD port?
Randy
2002 Boxster Seal Gray Metallic: Desnorkled, Changed ashtray to non-smoker's bin, Removed stickers from sunvisors, Added rear speakers, LED Shifter, Porsche logo on trunk lid, New top with heated glass window, Aspheric Driver's Side Mirror Upgrade, More to come...
randy7601 is offline   Reply With Quote
Old 08-20-2014, 09:42 AM   #2
Heiko's Avatar
15AMP in B8 should be the one... but other stuff is tied into that as well... anything else that's not working? It could be something else like a bad pin on the OBD port
Previously owned:
Old 08-20-2014, 09:53 AM   #3
On the slippery slope
JayG's Avatar
here is the fuse locations and descriptions
You should have a little book on the fuse panel cover
If you look at the fuses, you can see if one is blown. Probably need a flashlight.
2004 996 Targa Tip
Instructor - San Diego region
Old 08-20-2014, 06:12 PM   #4
Fuse B8 is ok. Other thought? Or do I need to check fuse-by-fuse?
Randy
Old 08-20-2014, 07:39 PM   #5
Try fuses B1 or B10 ("diagnosis").
Regards, Maurice.
schoir is offline   Reply With Quote
Old 08-21-2014, 08:00 AM   #6
epapp's Avatar
I hate to mention it, but the port wont do anything until the key is in the 'run' position I believe (it could be the 'on' position too, cant remember). The port has power all the time but wont have any data until you turn the key
epapp is offline   Reply With Quote
