-   -   OBD fuse? (http://986forum.com/forums/performance-technical-chat/53754-obd-fuse.html)
randy7601 08-20-2014 09:10 AM
OBD fuse?
:( Sorry to be needy on my first post. I'm trying to use the OBD port on my 2002 Boxster but the port is dead. I'm told to check the fuse and all should be well. I've searched here and google, but can't find the answer.
Which fuse is used by the OBD port?
Heiko 08-20-2014 09:42 AM
15AMP in B8 should be the one... but other stuff is tied into that as well... anything else that's not working? It could be something else like a bad pin on the OBD port
JayG 08-20-2014 09:53 AM
here is the fuse locations and descriptions
You should have a little book on the fuse panel cover
If you look at the fuses, you can see if one is blown. Probably need a flashlight.
http://986forum.com/forums/uploads01...1408557168.jpg
randy7601 08-20-2014 06:12 PM
Fuse B8 is ok. Other thought? Or do I need to check fuse-by-fuse? :confused:
schoir 08-20-2014 07:39 PM
Try fuses B1 or B10 ("diagnosis").
Regards, Maurice.
epapp 08-21-2014 08:00 AM
I hate to mention it, but the port wont do anything until the key is in the 'run' position I believe (it could be the 'on' position too, cant remember). The port has power all the time but wont have any data until you turn the key
