Old 03-11-2006, 01:07 PM   #1
Question Plugging 2 tires at Dougherty's cost $138?
I just paid Dougherty's of West Chester,PA $138 to plug two Kuhmo tires that had nails in them. Dougherty's indicated they take the tire off the rim, snip off the "mushroom" of the plug inside the tire and then patch over the interior. Is this a normal and reasonalbe procdure and cost?
Thanks,
Dan
Belledan is offline   Reply With Quote
Old 03-11-2006, 01:37 PM   #2
bmussatti
Guest
Posts: n/a
Did they re-mount and balance the tires?
What will you be using these tires for in the future?
Old 03-11-2006, 01:44 PM   #3
Unhappy Dougherty Tire Plug Costs
Dougherty's did rebalance the tires after plugging the two nail holes. My Boxster is a daily driver, no track use planned. I have Kuhmo's with 10,000 miles on them. In hindsight I would have preferred to invest the $138 into replacing the tires. I wish they informed me of the cost prior to doing the work.
Thanks,
Dan
Old 03-11-2006, 03:43 PM   #4
Hi,
Yep, they did a proper repair, but as you see, the cost is quite high and goes some distance to buying replacements. Take care at Speed however as these Tires are compromised. Not to scare you, as a normal street driven Tire, they'll be OK. Expect the repair to leak however in several thousand miles...
Happy Motoring!... Jim'99
Old 03-12-2006, 05:40 PM   #5
a shop that does repair without authorization? did you give them the go ahead without determining cost?
docdyh is offline   Reply With Quote
Old 03-12-2006, 06:08 PM   #6
Discount tire plugged two of my Kumhos and rebalanced them for $14.00 per tire. I was out the door for $28 plus tax. Your price is scary-high!
Old 03-12-2006, 08:10 PM   #7
Brucelee's Avatar
Talking
I would agree with Randall on this. Discount Tire is a deal on repairs.
Rich Belloff
Old 03-12-2006, 10:51 PM   #8
Hi,
Don't forget, for many of us, expensive optional or aftermarket wheels are part of the deal. Shopping for Discount work may not always be prudent. Make sure they have the proper equipment and properly trained personnel. It's also probably not a bad idea to get a comittment from them beforehand that if the wheel is damaged or scratched, that they'll pay for replacement/repair - could save a lot of frustration and work later. Also, if you have a digicam, it's not a bad idea to shoot a pic of the Tire/Wheel before you have the repair done so that there is no question should a wheel be damaged. Hope this helps...
Old 03-13-2006, 06:42 AM   #9
I think you should avoid this dealer. Isn't it also the one who charged $300 for an oil change?
1999 Boxster Red/Blk
2007 BMW 328 Coupe Arctic/Tan
1993 Lotus Esprit SE Red/Tan
rteichman is offline   Reply With Quote
Old 03-13-2006, 03:59 PM   #10
donv's Avatar
My local independent Porsche shop did my tire repair for free last year - same dismount, plug & patch approach. They also do your first oil change por nada as a "get a taste of our service" marketing deal. And they do great work, BTW. Those in the MA area should check them out - www.autosportengineering.com .
2001 Lapis/Black/Black, PSM, Rear Speaker Kit, Optima...
donv is offline   Reply With Quote
Old 03-15-2006, 03:29 PM   #11
olly986
Guest
Posts: n/a
Belledan
i am sorry to break it up to you but...
you've been screwed!!
i am sure if you went with a different car the price would be half, here the cost is between 10 to 20 Euros
sorry fella
Old 03-15-2006, 04:14 PM   #12
I second that opinion. By now he's probably planning a week in the Carribean with what he's charged you so far.
BTW that is the correct and proper way to "Patch" a tire. The discount tire way is way cheaper and does the same job.
KRZ
http://x402.putfile.com/2/5800280187-thumb.jpg
Voghtland 30-50mm Coilovers
19x8.5 x 19x10 Forgline rims
Magnaflow Exhaust
KRZTACO is offline   Reply With Quote
Old 03-15-2006, 05:11 PM   #13
Let me repeat what MNBoxster wrote - do not drive at crazy fast speeds now.
I have a plug in one tire and I limit myself to 100mph. Difficult, yes.
- Xavier
xavier405 is offline   Reply With Quote
