08-07-2014, 08:42 AM
#1
Boxster engine loom
Does a boxster have a seperate engine loom to the rest of the car?
as in, could you get the engine running on a stand.
Cheers
Rob
08-07-2014, 11:16 AM
#2
No.
The ECU has to see the low voltage multi-millisecond pulse that comes from the immob. for the start signal.
I take a stock chassis harness and pair it down to exactly what I need to run them on a dyno..
I've done this now for 5-6 years. We typically can pull 20+ lbs out of a 986 harness. 987 Cayman harness? 28-30lbs!!
Engine Builds, Transmission Builds, Engine Conversions, Suspension Installs, Suspension Tuning, Driver Coaching, Data Acquisition, Video, SCCA/PCA/POC/NASA/GRAND AM/ALMS.
We have worked with amateur and professional drivers for over 26 years. In house machinist, In house fabrication. Our cars, our parts, our engines, our transmission's run nationwide at events every weekend. We work side by side with industry names developing parts.
08-07-2014, 11:29 AM
#3
Here you go.. I test the harness before it goes back into the cars (and before we wrap it with the factory cloth tape.
08-07-2014, 01:18 PM
#4
08-08-2014, 05:32 AM
#5
hi brad, its for a rallycross car, so all i need is engine running, no lights etc.
as you have done it before, how much would you chard to cut down a loom for me?
Cheers
Rob
08-08-2014, 08:41 AM
#6
Hi Rob,
what year car? is it right hand drive or left hand drive? I typically do them on exchange, but I'm **guessing** you have a right hand drive car and I won't have a harness done already for a right hand'r.
I have in stock: 97-99 and 00-03 BoxsterS
I also have a 06-09 987 6speed harness
