Old 08-07-2014, 08:27 AM   #2
ppbon's Avatar
Are you sure that the Torx screw is turning? ...
... most likely the head is stripped.
Try using an extracting bit.
Happy Boxstering,
Pedro
Originally Posted by mprhh View Post
Hi guys,
1st post so go easy. I have a 99 Boxster with the horn honking under breaking fault. Don't worry I know how to fix it. However 1 of the T27 Torque screws just continues to turn not allowing the airbag to be removed.
Is it just a case of drilling it out completely or just drill the head out? Or is there a easier way?
Any help would be appreciated.
Racecar spelled backwards is: Racecar!
ppbon is offline   Reply With Quote
