Old 08-04-2014, 02:53 AM   #1
Part number help...
Hi All,
I'm looking for two part numbers, for a 2000 S. I've checked Pelican, various sites, and I downloaded a service manual that I found online, but no luck. Here's what I need:
1. Behind the front-left shock tower there is a round hole in the body that should have a body plug installed. Mine is open. The hole is about 1.5" in diameter.
2. Screw behind the door latch handle that is visible when the handle is pulled.
Thanks in advance.
Mitch
MitchSF is offline   Reply With Quote
Old 08-04-2014, 04:16 PM   #2
I called Pelican and they couldn't find the parts, either. So here's another question for anyone with a 2000 S - Looking through the front-left wheel just to the right of the shock, do you see a round hole, about 1.5" in diameter?
Old 08-04-2014, 04:35 PM   #3
3_Angels's Avatar
2002 Boxster S driver's side looking aft. Does this image have your hole? And if not, where would the hole be relative to this image?
3_Angels is offline   Reply With Quote
Old 08-04-2014, 05:00 PM   #4
The hole is in the wheel well. Looking straight through the wheel, you can see it just right of the shock. I'll pull the wheel tomorrow to take a picture.
Old 08-04-2014, 05:11 PM   #5
Here's a picture through the wheel. Shock is on the left, hole in the top middle, caliper bottom right.
Old 08-04-2014, 06:17 PM   #6
rdass623's Avatar
for the plug, go dig around in a junkyard and look for body plugs in the trunks and the floorboards of old junk cars. they are not Porsche specific. the screw is a #6, 3/4" screw available at just about any hardware store. pull the one from the other side of the car and match it up.
2005 Porsche Boxster S, 2000 Porsche Boxster 2.7L Base, 2000 Mazda Miata LS Supercharged, 2010 Toyota Tacoma TRD Off Road
Previous Vehicles: 2005 Ford Mustang GT, 1986 Alfa Romeo Spider, 1971 Alfa Romeo GTV, 1999 Ford Mustang
1977 Toyota Celica GT
rdass623 is offline   Reply With Quote
Old 08-05-2014, 02:35 AM   #7
Thanks. I'll try another source first, otherwise that's what I'll do.
Old 08-05-2014, 10:12 AM   #8
Mitch, This is what you're missing. The tube connects to something behind the hole it came out of. It didn't take much pulling to get out and I'm guessing yours just fell off. Of all my cars, only two still had one. I'm guessing it's a drain tube for water that might collect in the battery area. The rubber grommet slid up when I took it out. It should be about where my thumb is and only about an inch of the tube sticks out. I just mailed one to you along with the screw that goes behind the inside door handle.
Old 08-05-2014, 10:15 AM   #9
Thanks, Woody!
Mitch
