Old 07-20-2014, 03:53 AM   #1
Stainless Steel Headers/Manifold On Stock Muffler/Exhaust Opinions
Hi guys was thinking of getting stainless headers and keeping the exhaust stock. would I hear a different exhaust sound also would there be any drone? cheers
mangoman is offline   Reply With Quote
Old 07-20-2014, 04:10 PM   #2
Steve Tinker's Avatar
My first exhaust mod was installing SS headers to the standard system - seemed to rev & sound a little better above 4,000 rpm. No drone.
A couple of word of caution:
Removing the header bolts can be dangerous to your wallet - if they are corroded (you live in a rust area) they can snap off very easily, and removing the stubs can be very difficult.
You cannot re-use the plastic under tray as the headers fit lower than the standard items.
2001 MV Agusta F4.
Old 07-21-2014, 08:36 AM   #3
edc
550 Anniversary
edc's Avatar
You can use the undertray. I have done so on both my Boxsters now. You just need to crowbar a little bend where they are close.
I don't see the point of doing what you want to do though. I also did that but only becuase the exhaust i wanted to fit needed fettling and I then changed my mind, sold the Dansk on and got something else fitted at a later date.
Current: 550 Spyder Anniversary- Carnewal exhaust - 100 cell cats - stainless manifolds - 4" underdrive pulley - poly gearbox mounts - rear lower alu brace - adjustable rear toe links
Sold: 986S - Zenith Blue - 18" Sport Classics - Black Zunsport grilles - Stainless silencer and manifolds - K&N panel - shortshift - M030 suspension - 75mm throttle body - custom 83mm intake - SmartTop - custom remap - MDS underdrive pulley
