Old 07-14-2014, 05:48 PM   #1
Multiple cam-related fault codes
Friends, I could use some help.
I'm suddenly receiving three fault codes on my 03 986. Durametric reports this:
P0346:
Porsche fault code 113 - Phase sensor 2 (camshaft Hall-effect sensor 2)
P0335:
Porsche fault code 110 - RPM input circuit
P0021:
Porsche fault code 325 - Camshaft position with respect to crankshaft bank 2
I have already replaced the RPM (Reference) sensor, to no avail.
The running condition appears OK, although I believe there is a slight power reduction when this intermittent problem occurs. There is no problem starting or operating otherwise.
Can someone suggest the cause and solution?
Many, many thanks.
Ron
ChairmanRon is offline   Reply With Quote
Old 07-14-2014, 06:35 PM   #2
Do you know the cam deviation on bank associated with the sensor 2? Can you activate that sensor with the engine at idle and if you can, does it cause the engine to feel like it is bogging down?
Old 07-16-2014, 05:27 PM   #3
Here are the values that Durametric returns:
Camshaft position 2 deviation: -0.72
Actual angle for inlet camshaft bank 2: -1.19
Spec. angle for inlet camshaft bank 2: 0.00
Old 07-17-2014, 02:21 PM   #4
I was expecting the cam deviations to be farther out. I am not sure what may be happening.
Old 07-17-2014, 02:43 PM   #5
Start by diagnosing the cam position sensor. It could be as simple as a dirty/loose connector, check for voltage and check for shorts.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
