03-08-2006, 11:14 AM
Does Tire Repair Require Alignment?
I just had a puncture patched in the front tire of my 987. The car has only 3500 miles but since the tire was removed for the repair, do i need to have an alignment done?
I remember reading in another post about alignment for our cars being complex and requiring special laser equipment. I'm sure like everything else its an expensive procedure.
Thanks in advance for advice.
03-08-2006, 11:22 AM
Not unless your suspension was severely jostled when you got the hole. You may have to balance the wheel, but alignment only adjusts your suspension.
http://www.thecarspace.com/photos/8/...1481113d25.jpg
When people risk their lives, shouldn't it be for something very important?
Well, it better be.
But what is so important about driving faster than anyone else?
Lots of people go through life doing things badly. Racing's important to men who do it well.
When you're racing, it's life. Anything that happens before or after is just waiting.
03-08-2006, 11:27 AM
Dealer cost should be around $150.00 for alignment.
However, There shouldnt be a need to have an alignment done just because you "fixed a flat". I have had many flats fixed and never found a need for alignment. Just make sure they properly balance your tire.
-GT3 Front Bumper w/ Lip
-Side Skirts
-Gemballa Exhuast and Cats
-O.Z. Racing 18" Wheels
--18X8.5Front 18X10 Rears
-5mm Rear Spacers
-Porsche Door Sills
-H&R Springs
-Powerflow Intake
-B&M Short Shifter
-Focal Polyglass 165VR3
-Alpine PDX 5 Amp
-Audio Controld DQXS (DSP)
03-08-2006, 11:46 AM
great information. Thanks for the replies!
03-08-2006, 11:58 AM
I know this is a controversial topic, but most of what I have read on the subject, patching speed rated tires is not recommended. Others on this Forum disagree.
03-10-2006, 05:15 AM
Patching a speed rated tire is not a great idea. You can do it and get away with it, but your asking for trouble.
If your doing 150mph and it lets go because the tires do get hot then what? You're dead. If it's in the deep part of the tread then usually ok, if its in the shallow part near the wear bars your askin for it but can get away with it. If you on the outside near the sidewall your just retarded for fixing that.
I know tires are expensive but so if your car and life is pricess so don't chance it.
Regarding the algnment, if you hit a curb and poped it then yeah you'll need an alignment. If you just picked up debris off the road, I wouldn't worry so much about it.
03-10-2006, 06:39 AM
HI,
I've been around Racing enough that I've seen many Tires Blowout at high speed. The results often aren't pretty.
I'm not a Fan of repairing a Performance Tire, because the Tire is compromised for further High Speed use. But, there is a repair method which will allow a Tire to perform on the Street (albeit usually for a shortened lifespan). This is the Plug & Patch method.
This requires unmounting the Tire, pushing in a Plug and adding a Patch over the Plug where it protrudes on the inside of the Tire. Then the Tire must be remounted and balanced for a proper repair.
Unfortunately, most Shops do not perform this repair unless specifically directed to do so, and most Drivers are either averse to the added cost - $50+, or oblivious to the procedure altogether and don't insist on it.
As mentioned, you, your passenger and your Car are worth biting the bullet and getting the Tire replaced, and so are the other folks on the road, like me. I don't relish the thought that drivers I'm sharing the Road with are all on compromised Tires. Let your conscience, not your wallet, be your guide...
Happy Motoring!... Jim'99
03-10-2006, 07:16 AM
Hey Jim, what is it exactly that causes a really good plug and patch job to come loose at speed, causing a blowout?
03-10-2006, 11:27 AM
Thanks for the lively discussion. I have never patched a tire before, for the reasons you mention. However this time there were a few mitigating circumstances:
1. the tire has only 3500 miles on it, it was a simple puncture from debris.
2. the dealers were no help--they said they don't sell tires and refered me to a high performance tire shop.
3. The shop told me the tires were a new model and would take a while to find and get (i guess porsche modified the standard Continental tires for the 987 and they are not widely available).
4. My driving is city driving, with very rare instances of reaching 75 on the congested LA freeways.
That being said, perhaps i should have the shop find the tire and replace it. Another question:
given the low mileage, can i get away with replacing only the one, or do i need to replace the other front tire as well.
What procedure needs to be performed once the new tires are on?
03-10-2006, 11:35 AM
TVC What dealer in the LA area did you go to? Also what shop did they send you to?
-Side Skirts
-5mm Rear Spacers
-Porsche Door Sills
-H&R Springs
-Powerflow Intake
-B&M Short Shifter
-Alpine PDX 5 Amp
03-10-2006, 12:47 PM
I called Downtown LA Porsche and Beverly Hills Porsche. Downtown referred me to Globe Tire on La Cienega at Venice Blvd. They were very professional and said that they do a lot of Boxs.
03-10-2006, 01:01 PM
Hey your right in my area....best place that i would say to go is Wheel Enhancements in Culver City....They ONLY do Porsche Wheels and Tires nothing else. I would listen to them, they are the only ones i trust replacing my tires...
Let me know if i could be of any help to ya...
-Side Skirts
-5mm Rear Spacers
-Porsche Door Sills
-H&R Springs
-Powerflow Intake
-B&M Short Shifter
-Alpine PDX 5 Amp
03-10-2006, 04:26 PM
"Sorry about the length probably much more than you wanted to know . . ."
Not at all, I always appreciate it when someone takes the time to provide detailed responses.
"Another question:
given the low mileage, can i get away with replacing only the one, or do i need to replace the other front tire as well."
The owner's manual states that up to 30% difference in treadwear is permissible on the same axle.
So reading your post prompted me to do something that I've been meaning to, and that is check out the emergency tire-inflation equipment that comes with the car.
For what it is, I'm mildly impressed. The air compressor looks to be of high-quality (plugs into the cigarette lighter). I guess the upside to this is that if I need to put air in my tires I no longer need to go to a gas station, which is pretty cool.
The sealant goodies stocking stuffer looks more robust than the can of "fix-a-flat" available at Los Tres Amigos, but obviously is limited in the situations it can be applied.
The stuff is accessible by unlatching the compartment at the bottom of the front trunk. I also found the little tool kit, I've read about.
All told, I feel a little better, but suspect that one day we'll read about some poor 987 owner whose bones were left to be picked over by prairie dogs when he caught a flat in the Mojave.
06 987S- Sold
05 987 5-speed - Sold
06 MB SLK350- Lease escapee
03-10-2006, 11:40 AM
You should be OK with just replacing the one tire. This is a good question, because you don't want to set-up an unnecessary stagger. New tires are about 10/32. You can measure to make sure you are not setting up a stagger. I doubt it with only 3,500 on the fronts.
You still may want to save the old tire, have it patched, and use as a spare for emergencies- just a thought. You'll need to store it at home.
