You should be OK with just replacing the one tire. This is a good question, because you don't want to set-up an unnecessary stagger. New tires are about 10/32. You can measure to make sure you are not setting up a stagger. I doubt it with only 3,500 on the fronts.
You still may want to save the old tire, have it patched, and use as a spare for emergencies- just a thought. You'll need to store it at home.
