Old 04-25-2014, 09:24 AM   #1
Iowa
Marty Talarico's Avatar
99 986 starting problem
My 1999 Boxster wouldn't start at all, but when I put the key it it, it turned and the radio worked, power windows, seats, top, locks, heater, the norm.. But I unhooked the CPU in the back, and hooked it back up and now the key won't turn. I'm taking it next week to fix the starting problem, but now I added to that. Any thoughts on how I can fix this?
Marty Talarico is offline   Reply With Quote
Old 04-25-2014, 11:32 AM   #2
Before you panic, check to see if it is simply the steering wheel locking the ignition.
2016 4Runner TEP
Muzzle of Bees is offline   Reply With Quote
Old 04-25-2014, 12:01 PM   #3
doragman's Avatar
might be the clutch switch ...pump the clutch a few times and see if that works...or the ignition electrical switch
'99 986 Baton Rouge, LA
doragman is offline   Reply With Quote
Old 04-25-2014, 05:49 PM   #4
Ckrikos's Avatar
I would try the clutch switch and ignition switch first. Only 45$ in parts.
Sent from my LG-LS980 using Tapatalk
LB/GG/MB 02 2.7 sold
MB/GG 02 996TT
Old 06-11-2014, 08:01 PM   #5
Iowa
OK The steering wheel was very locked. I didn't want to brake the steering wheel, so I wiggled till it broke loose.
Thanks for the input guys!
