99 986 starting problem
My 1999 Boxster wouldn't start at all, but when I put the key it it, it turned and the radio worked, power windows, seats, top, locks, heater, the norm.. But I unhooked the CPU in the back, and hooked it back up and now the key won't turn. I'm taking it next week to fix the starting problem, but now I added to that. Any thoughts on how I can fix this?
Before you panic, check to see if it is simply the steering wheel locking the ignition.
might be the clutch switch ...pump the clutch a few times and see if that works...or the ignition electrical switch
I would try the clutch switch and ignition switch first. Only 45$ in parts.
Sent from my LG-LS980 using Tapatalk |
OK The steering wheel was very locked. I didn't want to brake the steering wheel, so I wiggled till it broke loose.
Thanks for the input guys! |
| All times are GMT -8. The time now is 11:31 PM. |
