Old 06-03-2014, 11:16 PM   #1
Porsche9's Avatar
Under drive pulley
I put on a under drive pulley earlier this year and have felt the few extra horses it provides was worth it. I was a little worried about when it gets hot (110 the other day) that I would possibly have problems with the car overheating and the A/C not cutting it. So far neither has been an issue. The A/C is as good if not better then other cars I owned. Thought some of you would be interested in my observation since we have extreme heat that puts these two systems to the test.
03 Carrera
89 Carrera 4
89 944 S2
78 911SC
Old 06-04-2014, 06:52 AM   #2
seningen's Avatar
I found that if I'm idling with a UDP and not-running the AC -- the coolant temp rises above
normal. I believe this is because without the AC the idle speed is low enough there
isn't enough WP rpms to get good coolant flow.
Put the AC on -- no issues.
YMMV,
Mike
Drivers: '15 Panamera Hybrid (wife's), ' 01 996 GT2, 00 Boxster S, '96 993 Çab/Tip (wife's)
Race Cars: '75 911 RSR Replica & '99 Spec Boxster
mike@lonestarrpm.com
seningen is offline   Reply With Quote
Old 06-08-2014, 04:16 PM   #3
Moderator
Texan here. I had my worries too with a 4in UDP. The A/C is great, idling is not an issue.
Old 06-08-2014, 08:35 PM   #4
Porsche9's Avatar
YMMV,
Mike
Tried both and it seems to make no difference. Idle speed also does not seems to change.
03 Carrera
89 Carrera 4
89 944 S2
78 911SC
