Old 02-28-2006, 08:15 PM   #1
Power Steering Fluid ????
New Kid on the block here. Just purchase my 1st Porsche (01 Boxster with 39,000 miles) and looks like it needs power steering fluid in a big way. Level does not register on the dipstick, or even on my finger when I stick it in the resevor. When going lock to lock on the wheel, I did not hear any unusual noise from the PS pump, I had it up on the rack and did not see any fluid leaking, or signs of a leak. The manual call for only Porsche approved fluid when replacing, but I'm assuming regular old (good quality) power steering fluid from Autozone is OK, right? Just as reference, is there anything else to check, quick check before I go another 6,000 to the dealer for teh 45,000 service package?
mwh98 is offline   Reply With Quote
Old 02-28-2006, 09:46 PM   #2
bmussatti
Guest
Posts: n/a
Welcome!
Now as far as the power steering fluid you must use the Pentosin CHF 11 S. This is sold at the dealers and at some automotive stores. Make sure you buy the correct fluid if you go to an automotive store. This product can be confused with the brake fluid. Should either one of these be put in the wrong system it will ruin it.
Pentosin power steering fluid is available at you local dealer. The part number is 000 043 203 33 in a 1000 ml container.
Old 03-01-2006, 05:47 AM   #3
Porschekid's Avatar
I know my Audi needs special mineral oil in the power steering fluid or it can seriously mess it up. I would be careful what I put in there.
http://www.thecarspace.com/photos/8/...1481113d25.jpg
When people risk their lives, shouldn't it be for something very important?
Well, it better be.
But what is so important about driving faster than anyone else?
Lots of people go through life doing things badly. Racing's important to men who do it well.
When you're racing, it's life. Anything that happens before or after is just waiting.
Porschekid is offline   Reply With Quote
Old 03-01-2006, 08:54 AM   #4
You are very right!!
After posting the SP question, I went on a mad search on the web, looking for answers. I found everthing from drain the Pentosin CHF 11s and replace with Dextron II or III, to "don't worry the government requires all lubricants to be compatible, go ahead and mix 'em", to all to don't mess with and never mix Pentosin with anything. I'll follow the later of the two. I managed to find a liter of Pentosin at O'Rileys Auto Parts locally, behind the counter for $25.99. Cheap insurance for a potentially major repair. Thanks for the response. Mark
Old 03-02-2006, 02:01 PM   #5
Well, after speaking with the dealer, the took care of things for me by getting the Pentosin for me, only the local Porsche dealer uses Pentosin CHF 202 ($16.00 per liter) as opposed to Pentosin CHF 11s ($25.00 per liter). When I asked if this was the correct stuff, ther dealer showed me the side of the can that said "compatible with CHF 11s". SO if you can find Pentosin 202, it is almost half the price of 11s.
Old 05-26-2007, 03:23 PM   #6
Porscheectomy
https://www.pca.org/tech/tech_qa_question.asp?id={BE56ED8B-6293-43EA-B84F-682E2244059A}
Sorry about reviving the old post, but your dealer is taking a chance at your expense.
