Welcome!
Now as far as the power steering fluid you must use the Pentosin CHF 11 S. This is sold at the dealers and at some automotive stores. Make sure you buy the correct fluid if you go to an automotive store. This product can be confused with the brake fluid. Should either one of these be put in the wrong system it will ruin it.
Pentosin power steering fluid is available at you local dealer. The part number is 000 043 203 33 in a 1000 ml container.
