Old 05-27-2014, 11:28 AM   #1
truegearhead's Avatar
Airpump removal help please
I'm going to remove my airpump and it's corresponding parts this week to further reduce weight. Do I need to keep anything in mind when pulling these parts out? For example do I need to plug any of these lines in the diagram below?
2003 911 C2
NASA HPDE Instructor
Old 05-27-2014, 08:36 PM   #2
Have you considered something like this;
Porsche Boxster Secondary Air Block Off Plates
Old 05-27-2014, 08:54 PM   #3
golonaus's Avatar
yeah you need 2 block off plates. its like 20$ or so
99' with 3.4l engine. ROW tune. SAI delete
Old 05-28-2014, 05:40 AM   #4
Awesome thanks guys. I just emailed Nike and Mike, looks like they're out of stock.
2003 911 C2
Old 05-28-2014, 07:16 AM   #5
Just order from your favorite parts supplier
(1) 996 113 140 53 plate
(1) 996 113 233 50 gasket
(1) 996 113 340 50 plate
(1) 996 113 213 51 gasket
MaxD is offline   Reply With Quote
Old 05-28-2014, 08:55 PM   #6
com3dorm3's Avatar
I'm thinking about doing this too.
How involved is the process? From the diagram it does not look too bad.
Also, is an ECU mod required? I assume this would trigger a cel, right?
2000 Boxster S
com3dorm3 is offline   Reply With Quote
Old 05-29-2014, 06:37 AM   #7
golonaus's Avatar
I got mine from a local dealer
Old 05-29-2014, 07:01 AM   #8
That's were I ordered mine as well, any advice on the removal? How long did it take you?
2003 911 C2
Old 05-29-2014, 07:53 AM   #9
golonaus's Avatar
Really easy project on my 3.4 with clearance issues. I bet it can be done in 2-3h. It took me a weekend due to hot summer and cold beer.
Old 05-29-2014, 11:13 AM   #10
One more question. What are you supposed to do with #7 in the diagram? The kit I purchased doesn't include something to fill the hole that this component fits into
2003 911 C2
Old 05-29-2014, 11:42 AM   #11
golonaus's Avatar
I think this is check valve. Nothing to plug up. You will need to relocate vacuum canister and make a bracket 4 it tho
Old 05-29-2014, 01:16 PM   #12
Yes, the ECU will have to be modified to ignore the SAI test or you will get a CEL. Most common is a ROW re-flash.
