Old 05-21-2014, 02:44 PM   #1
Beginner
Jamesp's Avatar
Two fans or one?
Should both cooling fans run at the same time or does one lag the other?
2003 S manual
Old 05-21-2014, 03:01 PM   #2
1999 base
Meir's Avatar
both run at the same time.
low speed and high speed.
if you have issue with one of the fans or speed, most chances its a bad fan resistor.
the resistor is located on the bumper next to each one of the fans.
Old 05-21-2014, 03:46 PM   #3
Registered Boxster abuser
healthservices's Avatar
If one starts then the other follows after a while, try this... As soon as one fan goes on, tap on the other fan motor with a small hammer. If the fan starts the fan's brushes are toast and are barely making contact. Replace fan motor.
Old 05-21-2014, 06:43 PM   #4
Beginner
Jamesp's Avatar
Thanks! I'll go check it out.
2003 S manual
