Old 05-08-2014, 12:54 PM   #1
Steel IMSB
If you have installed a replacement steel IMSB, which one did you install? Why?
If you are planning a new steel bearing installation, which one have you chosen? Why?
Thank you.
A.C.T.
mugwump is offline   Reply With Quote
Old 05-08-2014, 03:44 PM   #2
Beginner
Jamesp's Avatar
I replaced the stock NSK with a Nachi bearing with full Viton seals and high temp grease. I chose this because the Viton in the Nachi is a superior material at temperature and I wanted a higher temperature bearing. Choosing a fully sealed bearing was also important to keep the oil and grease separate. The caveat is I also modified my IMS shaft to eliminate the pressure differential in the IMS that will push oil through the bearing seals.
2003 S manual
Old 05-09-2014, 08:11 AM   #3
James,
Thank you for the reply. I appreciate your willingness to help. I have read several of your related posts with interest.
Best regards,
A.C.T.
