Old 04-05-2014, 03:09 PM   #1
jsceash's Avatar
3.2 and 2.7 clutch?
Does anyone know the difference in a 3.2 clutch and pressure plate and the 2.7
Old 04-05-2014, 03:27 PM   #2
BYprodriver's Avatar
Clutch splines are different between 5-speed & 6-speed. If you have a 5-speed I think you want the 987 version which has more holding power according to Pelican.
FYI the 987 6-speed splines are different from 986 & NOT interchangeable regardless of what Pelican states in the tech info section. I had the displeasure of verifying this personally!
Old 04-05-2014, 03:43 PM   #3
jsceash's Avatar
Thanks for the info, good to know. I guess I get a level 2 Spec or Clutch Masters Kit.
