Old 04-04-2014, 03:48 AM   #1
I think I stuffed up
Did a clean on the throttle body & after removing all the carbon with carby cleaner there were some small ridges that I polished off with autosul & the throttle body was quite shiny compared to before.
Now she has inconsistent idle & poor throttle response under 2K.
Will have another look at it tomorrow. Should I unpolish?
http://i13.tinypic.com/49ied5h.jpg
2000 2.7 Boxster
aussieboxy is offline   Reply With Quote
Old 04-04-2014, 04:30 AM   #2
linderpat's Avatar
sounds more like there is a vacuum leak somewhere. Double check very carefully how everything was put back together. Also, look to see if you knocked off any wire harness connectors while you were either pulling off the TB or putting it back on.
Ed
Pittsburgh, PA
78 5 spd 928 Blumaxx (in Hemmings S & E issue #100)
85 928S garnet red stock daily driver
06 Mustang GT Legend Lime and modified to go even faster
linderpat is offline   Reply With Quote
Old 04-04-2014, 06:23 AM   #3
If its not egas, also check the idle control valve, some crud may have flowed in there.
Lon Tusler
1999 996, Track Only #996
Everything Jake could upgrade, and more!
ltusler is offline   Reply With Quote
Old 04-04-2014, 12:34 PM   #4
DennisAN's Avatar
I come from a background of Japanese cars, but.....
Throttle bodies may have a "plastic" layer installed right where the throttle plate rests when closed. This serves as a "gasket" to ensure complete closing, with idle air supplied from a bypass. It's a common error reported in certain forums to over-clean throttle bodies with harsh chemicals (e.g. carb cleaner) which removes this carefully-manufactured plastic layer. Then the throttle body will forever leak a random amount when the throttle plate is closed. In the US there's a special "throttle body" cleaner sold that's less harsh than carb cleaner, ostensibly to not remove this plastic liner.
Base 2000 986, beater 1996 Miata, 2011 Suzuki SX4 AWD
Feline mechanics Condoleezza and Dukie
DennisAN is offline   Reply With Quote
Old 04-30-2014, 05:03 AM   #5
Sorted itself out. After daily driving for a couple of weeks it eventually returned to normal.
Got me stuffed.
2000 2.7 Boxster
Old 04-30-2014, 08:47 PM   #6
rdass623's Avatar
if you are concerned with fuel system cleanliness, may I suggest marvel mystery oil. this stuff is great at cleaning out carbon and varnish from fuel systems. I recently purchased my boxy with under 50k on the odometer. as I was driving home from the purchase, I tripped a CEL and read it with my el-cheapo code reader. o2 sensor.... so being the diligent owner I am I ordered 4 o2 sensors. while waiting for the order to come in, I added 4oz of MMO to the gas with my refill. the idle smoothed out CEL went out and the performance increased (no dyno test, so don't ask). sometimes some of those old school remedies still work out, now I add a few ounces to the gas as a preventative measure. now I have 4 brand new 02 sensors sitting in their original packages at the house (will keep them around for when they are really needed).
2005 Porsche Boxster S, 2000 Porsche Boxster 2.7L Base, 2000 Mazda Miata LS Supercharged, 2010 Toyota Tacoma TRD Off Road
Previous Vehicles: 2005 Ford Mustang GT, 1986 Alfa Romeo Spider, 1971 Alfa Romeo GTV, 1999 Ford Mustang
1977 Toyota Celica GT
rdass623 is offline   Reply With Quote
