Old 03-30-2014, 05:44 PM   #21
Reebuck1
Got it! Thanks guys.
Reebuck1 is offline   Reply With Quote
Old 04-16-2014, 07:38 PM   #22
On the slippery slope
JayG's Avatar
Originally Posted by j.fro View Post
I hooked up my Durametric today to look at camshaft deviation specs. Do these look good? Is there anything else I should check?
2000 Boxster S, 167,000 miles, original IMS:
Bank 1: -5.63
Bank 2: -6.5
remained unchanged regardless of RPM
1999 Carrera 4, 77,000 miles, just replaced IMS w/LNE:
Bank 1: -6.56
Bank 2: - 4.39
I was looking to get air-fuel ratios, but couldn't find that function in Durametric... am I missing something?
Will the Enthusiast version show camshaft deviation?
2004 996 Targa Tip
Instructor - San Diego region
Old 04-17-2014, 12:43 AM   #23
Steve Tinker's Avatar
Mine does.....
2001 MV Agusta F4.
Old 04-17-2014, 06:35 PM   #24
N0tt0N's Avatar
JayG: The software is identical and has all the features for any version. The 'version' is of the cable and only determines how many VINs can be used - 3 vs unlimited.
Martin
2002 Boxster S
2006 Cayman S
N0tt0N is offline   Reply With Quote
Old 04-17-2014, 06:43 PM   #25
steved0x's Avatar
The pro version lets you do more coding or writing of settings of the car, while the enthusiast is more read only and limited to 3 vins. All of the monitoring functionality is the same for both.
Old 06-09-2017, 01:47 AM   #26
Swhitcomb's Avatar
Engine is a rebuild with only about 20k on it. Jake has me panicked.
02 Boxster
71 VW Karmann Ghia
71 VW Super Beetle
Swhitcomb is offline   Reply With Quote
Old 06-09-2017, 04:28 AM   #27
I just changed mine out. It was expensive.
http://986forum.com/forums/general-discussions/66475-sad-day-my-bank-account.html
If you're going to do this yourself, it's an advanced job, so be prepared. You don't have to drop the entire engine, just lower it enough to access the cam banks.
And while you're at it, it's best to pull the oil pan and check the pickup tube. The bits and pieces of these wear pads tend to clog up the screen.
Need_for_speed is offline   Reply With Quote
