Old 03-17-2014, 03:30 PM   #1
3_Angels's Avatar
Newbie 02 6sp Boxster S owner, oil on top of engine?
There is oil on the top of the engine and as shown in the images. Where should I start looking for leaks?
3_Angels is offline   Reply With Quote
Old 03-17-2014, 04:42 PM   #2
Beginner
Jamesp's Avatar
The Air Oil Seperator (AOS). Pull the fitting where the bent plastic AOS tube goes into the manifold by the throttle body and see if there is standing oil in that area. A little is ok, but if it is pooling / everything is covered in oil change your AOS. I had to do that and now there is almost zero oil in that area.
2003 S manual
Old 03-19-2014, 04:49 PM   #3
3_Angels's Avatar
OK, will pull the AOS tube you referenced tonight if the pool team doesn't keep me up too late. Thanks
Old 03-25-2014, 10:30 PM   #4
3_Angels's Avatar
Which hose?
The attached image has the AOS hoses shown. Which hose am I supposed to check; 1, 2, 3, or 4? Thanks
Old 03-26-2014, 07:46 AM   #5
Trey T's Avatar
#4 that goes to the intake manifold
Trey T is offline   Reply With Quote
Old 03-26-2014, 09:30 AM   #6
BYprodriver's Avatar
Pull 1&2 where they merge into the intake manifold & swab around the inside with your finger for oil etc.
Also check the pleated hose under the AOS for leaks & tears. It looks like a accordian & is clamped to the engine head.
