Old 03-02-2014, 03:41 PM   #1
size of the 'tripple square socket..?
required to remove the single weird bolt between the engine and gearbox..
I went to Sears and they told me that the 'triple square' sockets have to be special ordered, thanks in advance.
Regards, Gilles
Old 03-02-2014, 06:08 PM   #2
Rennzenn
j.fro's Avatar
I got mine from Advance Auto. It came in a set of 4 triple square bits; the set was under $10.
Rennzenn
Jfro@rennzenn.com
Old 03-02-2014, 09:06 PM   #3
Thanks J.Fro, do you remember which size is the one required to remove the transmission to engine bolt?
Old 03-03-2014, 03:04 AM   #4
Theoretical propagandist
Eric G's Avatar
TOL-KD2305 10mm Triple Square Socket $8.72
Click the link and its at the bottom of the page if you want to get it from Pelican.
http://www.pelicanparts.com/cgi-bin/ksearch/PEL_search.cgi?command=show_part_page&please_wait=N&make=POR&model=986M&section=TOLtol&page=4&bookmark=&part_number=TOL-KD2305]Porsche Boxster Tools - Page 4
Old 03-03-2014, 12:00 PM   #5
Topless's Avatar
Someone once mentioned that a 12pt 10mm socket will also work. I have not tried it but if your tool box is nearby, give it a test.
Edit: I just looked at the Pelican tool and it doesn't look similar to me at all.
Old 03-03-2014, 06:52 PM   #6
Jager's Avatar
Regards, Gilles
I recommend getting a short bit (or cut one) so you can do something like this:
Jäger
300K Mile Club
Old 03-03-2014, 08:20 PM   #7
lkchris's Avatar
Hate to be pedantic, but "socket" implies female. These tools are drivers. There are internal and external TORX fasteners, but this isn't the case with triple square/XZN, mostly due to semantics. There are 12-point head fasteners on, for example, BMW motorcycles, but the wrenches aren't called, for example outside XZN, just as hex-head fasteners aren't called outside Allen. Nobody calls an Allen driver a "socket." The Pelican page makes the error, too.
Kent Christensen
Albuquerque
2001 Boxster
2007 GL320 CDI, 2010 CL550
2 BMW motorcycles
Old 03-07-2014, 07:19 PM   #8
Porsche "Purist"
Paul's Avatar
Buy real tools ($8.50 from Snap on):
Socket Driver, Metric, Triple Square, Stubby XZN, Blue-Point, 10mm
1987 924S. 2002 996TT. PST-2
Old 03-08-2014, 07:25 AM   #9
The Radium King's Avatar
if you order from pelican, beware the porsche tax. the 5-speed is actually an audi transmission and requires the same tool. if you buy the tool from the porsche side of the pelican website - $32. if you buy the tool fro the audi/vw side of the pelican website - $8. the porsche tool is of course 'high performance'; it reduces the weight of your wallet by a few ounces.
Old 03-08-2014, 07:55 AM   #10
JAAY's Avatar
I bought mine in a set at Lowes. Not the best tools ever but has worked for years many times.
Old 03-09-2014, 05:47 AM   #11
Beginner
Jamesp's Avatar
I found that area very tight and used a setup like this with a much shorter triple square bit. I one dremelled on in half from Autozone, about $15 for four sizes as I recall
2003 S manual
