Performance and Technical Chat
Manually operated top...?
02-14-2014, 07:16 PM
jeroen
Read somewhere it was possible to remove the motor and transmissions and operate the top manually...
With the motor/trans out of the equation how does the clamshell "lock" when the top is either up or down?
02-15-2014, 02:34 AM
2
litespeedp
Would be a great idea.Always had manually operated convertibles.
All the the power items just add complexity,weight and cost.
How hard could it really be to raise and lower this tiny top! Count me in.
02-15-2014, 05:23 AM
3
Eric G
Theoretical propagandist
Eric G's Garage
Esmeralda
Gadget
Sasha
Gertrude
Bernice
Mrs. T
Here you go:
http://986forum.com/forums/general-discussions/43235-why-i-converted-manual-top.html
02-15-2014, 05:54 AM
4
jeroen
Just the info I was looking for. Thanks!
02-15-2014, 09:07 AM
5
Eric G
Eric G's Garage
Esmeralda
Gadget
Sasha
Gertrude
Bernice
Mrs. T
Glad to help. If you decide you want to go with clips, let me know I can send you the links for them. They are long lasting and inexpensive.
Have a great weekend!
02-15-2014, 12:12 PM
6
LAP1DOUG
Any estimated weight savings?
Thanks.
Kippis
986S
991S
Van Diemen RF97
02-15-2014, 12:30 PM
7
The Radium King
no scale, but i have the motor and transmissions in my hand right now and they feel like around 20 lbs.
02-15-2014, 06:14 PM
8
dghii
I'm not a fan. 20lbs weight means you've effectively gained a little over 1 Hp. Not worth it as far as performance.
The Boxster top mechanism is elegantly simple for what it does. I'll keep mine and repair if necessary.
Linear Mode
Switch to Threaded Mode
01:46 AM
