02-04-2014, 03:27 PM
#1
DIY convertible top install?
Any of you ever R&R your convertible top as a DIY project? How hard a job was it? Are the glass windows worth the extra $?
02-05-2014, 03:02 PM
#2
It's been discussed to death in countless threads. Do a search.
'99 black 986
02-05-2014, 06:55 PM
#3
DIY top
It can be done if you are careful. It is a lot of work and should be done in warm weather. (easier to stretch the canvas). Glass top is well worth it to me. I would carefully label each type screw and fittings. I did for but the last two screws and wouldn't you know it I forgot where they went. Figured it out much later now can't find the screws. Truthfully it was time consuming and lot of work. As mentioned by the other member there are numerous posts and downloads with instructions. Keep in mind there are variations and your top could be slightly different than the one in the instructions. The two plastic sliders and pins on the side are fairly cheap and easy to break. I would get new ones. Good luck
02-05-2014, 07:11 PM
#4
Theoretical propagandist
If you are patient and can pay attention to detail it is very doable. Mine only took an afternoon to complete. Mark however clearly makes a good point, there is ton's of data on the sight, so go do your homework!
02-06-2014, 01:25 PM
#5
How to do it with pictures here.
02-06-2014, 03:11 PM
#6
Thanks all!
02-17-2014, 05:44 PM
#7
That was my first DIY project on my Boxster. It took me a full day to perform the task. But the result is top quality. I did install the glass window. Lot better the only thing is the real glass is a little smaller so less vision with the top on. If you email me I can send you the instructions received with my new top.
If you want something done, give it to a busy guy!
02-17-2014, 06:25 PM
#8
I greatly admire you guys who replaced your own top. After replacing the top on an earlier owned Miata, I swore that I would never, ever, ever, ever replace a soft top again. So, when it came time to replace my Boxster top, I had a local shop do the install for an affordable $350. Best $350 that I ever spent.
03-17-2014, 01:19 PM
#10
Texas-T
Someone cut my top open with a knife, so i took it to the dealer, and it was covered by my insurance claim, minus the deductible. the dealers cost for the aftermarket top (with glass,) and interior liner, and labor was over $5k. I had to go back repeatedly, i don't even want to say how many times i had to back there, but lets just say i got to know the service guys very well during the process. On one visit, i had to take home an overnight loaner. Seems like it must be quite a tricky job if even they struggled with it! One thing to note, they told me not to open the replacement top for 30 days, because it needs time to stretch and break in just like a pair of new shoes.
"This all started with a simple oil change..."
Reason: i cant't spell to good
03-17-2014, 07:15 PM
#11
Let me guess, they warranty their work for 30 days, lol.
I think the dealer made out like bandits if they convinced the insurer to pay over $5k. You can buy a new top with glass for just over $500. Someone is scamming insurer. I've heard that a car upholstery shop will charge approx $500 labor to install.
03-27-2014, 11:00 AM
#12
I want to personally thank mikefocke for the awesome DIY. My top turned out perfect. I'm guessing you saved me $1k. I owe ya one Mike!  The only issue I had was the double sided tape didn't work too well, but I used spray adhesive and it worked well. Here is what I installed... Porsche 986 Boxster Convertible Top Black German A5 1997 2002 | eBay
:dance:
Chris Dennis, Plano, Texas
'07 Boxster, arctic silver, Tiptronic, 106k miles, no mods
‘13 Boxster S, black on black, PDK, 27k miles, garage queen
‘66 Mooney M20E, hangar queen
