Old 01-20-2014, 07:08 AM   #1
Gearbox oil change???
How often you used to change your gear box oil? My car has now seen 14 years and 160.000km and I´m wondering, should i change the oil already?
I´m going to test RedLine75W90NS.
riquuu is offline   Reply With Quote
Old 01-20-2014, 07:27 AM   #2
The Radium King's Avatar
every 48k kms. change it.
Old 01-20-2014, 07:47 AM   #3
oc-boxster's Avatar
my mechanic used the redline oil you listed, i was a bit nervous when he told me as i have read that only the porsche factory oil should be used. I havent had any issues with it. once the car is warmed up it shifts smoothly. I changed mine at 90,000 miles per my owners manual.
oc-boxster is offline   Reply With Quote
Old 01-20-2014, 08:03 AM   #4
Dlirium's Avatar
Way to long. Change it now.
Since you rarely do this anyway, why not go with the Porsche oil? All other oil has a TON of debate around it...
Old 01-20-2014, 08:05 AM   #5
Change it. Use the Porsche stuff. You only need to buy about 3 litre.
Old 01-20-2014, 08:12 AM   #6
steved0x's Avatar
I just did mine, 2000S, it took 2.8 L and I got the Porsche stuff, best price I found was from ECSTuning.com. It was relatively easy to do and it made a big difference in the feel of my shifting.
Steve
Old 01-20-2014, 08:52 AM   #7
Dlirium's Avatar
Steve
+1
Bought mine from ECS as well for my 2000 S. relatively easy project and shifting is improved. Changed mine at 115k miles, not sure if PM had ever done it or not, but made shifting much smoother and easier.
Old 01-20-2014, 09:42 AM   #8
Thanks for the advice. I already bought RedLine so i will test it anyway. I´m from Finland and nearest Porsche dealer is 400km away from my city, so it´s easier to buy stuff i can get from local shops.
I will write some experiences when a driving season begins. It´s still -20 Celsius here in Finland and Boxster rests in garage another 3 months
Old 01-20-2014, 09:56 AM   #9
I used the redline 75w90ns and it seems to improve feel and be working fine. having said that, I will most likely go to oem for my next change. I think the Porsche change interval is too long (similar to their oil change interval) and like to use the 48k km interval recommended by pelican:
Pelican Technical Article: Boxster Differential / Manual Boxster Transmission Fluid Change - 986 / 987
Old 01-20-2014, 10:22 AM   #10
steved0x's Avatar
Originally Posted by Dlirium View Post
+1
Mine was right around 109,000, and based on my service records I don't think it had ever been done (if it had, it was in the first 60,000 miles). It made a big difference
