Old 01-20-2014, 07:54 AM   #1
BruceH's Avatar
Meticulous surface preparation is everything. You can obviously do a better job if you remove the calipers from the car. A few cans of brake cleaner, a wire brush, and lots of rags should do the trick. Plug the holes with rubber stoppers and tape off the seals.
I used VHT caliper paint and it seems to be holding up well.
I did the same, brake cleaner, wire brush, some sand paper, clean, mask, VHT red, stickers from eBay, and then VHT clear.
2001 Boxster S Lapis Blue
iPad Mini Dash Install
DEPO Tail Lights
Old 01-20-2014, 08:30 AM   #2
Awesome comments, thanks! I'm going to try it.
Dave2001S is offline   Reply With Quote
Old 01-20-2014, 09:01 AM   #3
Dlirium's Avatar
Post a link to the caliper stickers that are mentioned if you find them on Ebay...
Old 01-20-2014, 09:15 AM   #4
BruceH's Avatar
Here you go:
6 Porsche Prem High Performance Brake Caliper Decals | eBay
DEPO Tail Lights
Old 01-20-2014, 09:50 AM   #5
Dlirium's Avatar
Thanks for posting!
Old 01-20-2014, 10:09 AM   #6
Registered Boxster abuser
healthservices's Avatar
porsche caliper stencils | eBay
I like the stencils better as you use paint instead of a sticker.
just make sure to use the correct size, as there are fanatics will point out that they are incorrect if too big or small. :ah:
