Old 01-20-2014, 07:54 AM   #1
BruceH
BruceH's Avatar
Meticulous surface preparation is everything. You can obviously do a better job if you remove the calipers from the car. A few cans of brake cleaner, a wire brush, and lots of rags should do the trick. Plug the holes with rubber stoppers and tape off the seals.
I used VHT caliper paint and it seems to be holding up well.
I did the same, brake cleaner, wire brush, some sand paper, clean, mask, VHT red, stickers from eBay, and then VHT clear.
2001 Boxster S Lapis Blue
iPad Mini Dash Install
DEPO Tail Lights
