Old 01-16-2014, 09:43 AM   #1
Registered Boxster abuser
healthservices's Avatar
Loctite 5900... Who really likes this stuff?
So who uses this stuff?
I think its just over priced cheap silicone, and will most likely never use it again. Something to be used in a clean room environment, and it does not seem to be a great sealant for the enthusiast or the gen shop.
It seems that the surfaces have to be impeccably clean of oil otherwise it won't stick well.
What else do you use?
My current sealer of choice is still Hondabond and Hondabond HT.
Old 01-16-2014, 10:25 AM   #2
BYprodriver's Avatar
I use the Dri-Bond specified by Porsche. All sealing surfaces must be clean enough to eat off of. I think the same company makes Honda Bond.
Old 01-16-2014, 12:11 PM   #3
LOL... youre complaining about sealing surfaces needing to be impeccably clean of oil? That is a prerequisite for ANY gasket...or did you think that even your favorite honda silicone was going to stick to grease? And as for the clean room comment, thats what I use to seal Porsche engine blocks, and you better believe everything is spotless.
Thats actually really good silicone, I'm not sure why you dont like it. I usually clean the surfaces with a Mirlon scuff pad ( the red one is very fine and doesnt leave any scratches ) and then take rubbing alcohol or brake cleaner, soak a rag with it, and go along the sealing surface until its oil free.
And please dont lay that silicone on too thick, just a bead maybe 1.5mm thick is plenty. Remember that the excess ends up in the oil pump feed strainer....
As for regular stuff? I use Permatex's "the right stuff"
Bigsmoothlee is offline   Reply With Quote
Old 01-16-2014, 12:33 PM   #4
I know we have our OCD people here and can understand where they are coming from but...
Its quite a bit pickier. I can clean up the oil and gasket, spray clean with parts cleaner, and then clean with alcohol and still it does not stick anywhere near as well as hondabond can.
Please remember the company who sells the product for hondabond also sells a similar product for other car companies. I use Hondabond because it easy to get.
Hondabond just flows and sticks. I use the runny stuff for flanges, and just use a paint brush to put it on. The loctite stuff is like trying to put Vaseline on.
Old 01-16-2014, 12:50 PM   #5
For flanges... 1.5mm is already too thick. Paint it on and thin as you can. As long as there is no break in the sealant bead you are good to go. In a perfect world sealant is not nec. but its not perfect so we have to have something to fill the voids.
I rarely use sealant on items with gaskets, but I do put a tiny bit in the corners.
Old 01-16-2014, 06:07 PM   #6
Beginner
Jamesp's Avatar
5900 rocks. Ive used loads of silicones and was quite the skeptic until I actually used 5900. Having said that I have not used Hondabond HT and will look into it. High priced? oh yeah, but it does not set up to a point where it will shear like other silicones I've used and does not grab with the grip of death that makes any relative joint movement a recipe for pealed silicone. I like it.
2003 S manual
Old 01-16-2014, 06:46 PM   #7
Depends on what you are using a gasket maker for. On the sump plate, I use permanent red, as little as absolutely possible. Works fine. Now, if I were resealing the cam covers, I would only use the P spec sealant.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
Old 01-16-2014, 10:53 PM   #8
The one thing I will say about hondabond... if you have to go back in to reseal.. which will be a long time if you did the job right, it will not be easy to remove. 5900 if that was what was on there before when I did the last job, scotchbrite and its gone.
Old 01-17-2014, 07:08 AM   #9
We use both the Dri Bond and Loctite 5900. The 5900 is an excellent product and not at all hard to use, and does an excellent job of sealing, so I do not see the problem here......
Old 01-17-2014, 08:14 AM   #10
Ill try using it more, must not be use to the consistency of the product.
Sent from my SM-T310 using Tapatalk
Old 01-17-2014, 09:15 AM   #11
+1 The 50ml tube of Dri-Bond is barely enough to assemble 1 engine. It is a pain to get all the sealant out especially once it gets old. Rather than buy a new tube just for a sump plate I use Permatex Ultra Grey.
Old 01-17-2014, 09:17 AM   #12
5900 is black & harder to remove than Dri-bond which is clear.
Old 01-17-2014, 09:48 AM   #13
Hmm the stuff that was on there must not have been 5900. Probably some type of cheap sealant, as it was a black sealant with a soft jello consistency
Old 01-17-2014, 03:50 PM   #14
jsceash's Avatar
I don't like it but it did work as good or better than any other compound I ever used. The 3.6 engine took me about 3/4 of a tube. after 7800 miles I have no leaks what so ever
Old 01-19-2014, 06:45 PM   #15
Beginner
Jamesp's Avatar
Good lord! I just had to remove my valve covers to re-time after a couple of weeks with 5900 setting up. Why use bolts? The 5900 was not letting go! It does not set up like RTV. and once the covers are off, a hard plastic scraper removes it from the aluminum, but gettnig the covers to pop free? I thought I was going to break them.
2003 S manual
Old 01-19-2014, 09:18 PM   #16
Engine Surgeon
You won't find a Raby engine with 5900 anywhere on it!
US Patent 8,992,089 &
US Patent 9,416,697
Old 01-20-2014, 04:50 PM   #17
Beginner
Jamesp's Avatar
What do you prefer?
2003 S manual
Old 01-20-2014, 06:23 PM   #18
I use 5900 (sparingly). Track or street, never had a leak. With that said, I don't think that its got any magical properties, any good sealant will probably work as well.
